Classifieds require "Engine" field for Accessories? I am trying to post a progressive nitrous controller for sale. It is an electronics accessory which can fit all cars, but the Classifieds requires an engine choice. Doesn't seem to make sense. Perhaps the Engine field requirement could be ignored for certain categories? In addition, the Classifieds tool could be made more user-friendly when it detects an "error". Now, it just tells you that a field is missing a value, and if you hit the 'Back' button, you have lost all your text. Any chance of detecting an error then putting you back into the Edit mode with all your text still there? Thanks, Jim |
Bump....having precisely the same problem. Tried this 3 times, starting over from scratch each time and no dice. Any thoughts. |
Are you having the same issue with the engine field required for an Accessory item, or are you receiving a different error? If so, what error is it?
Originally Posted by Midnight02
(Post 16072650)
© 2024 MH Sub I, LLC dba Internet Brands
