What cam is this ?
Old 07-20-2017, 02:59 AM
MAG1C's Avatar
Default What cam is this ?
53r 110+3
2870h
Old 07-20-2017, 09:28 AM
MAG1C's Avatar
Anyone?
Old 07-20-2017, 10:48 AM
Gearhead1's Avatar
Well, it's a Comp Cam, but I can't find that lobe profile anywhere in their (online) master catalog. http://www.compcams.com/Technical/Ca...terCatalog.pdf If you scroll down to the last pages of the catalog, they have all their lobes listed in a lobe index. Yours (2870) should be listed on page 162, but isn't. I do know (for a fact) that they have lobe profiles that aren't listed in their catalog. I'd give them a call, I'm sure they'll be able to help you.
Old 07-20-2017, 01:17 PM
MAG1C's Avatar
Thanks bud I'm gonna give them a call
Old 07-20-2017, 01:21 PM
MAG1C's Avatar
Just called and they assured me that it's not there cam
Old 07-20-2017, 04:00 PM
Received 3,021 Likes on 2,352 Posts
And now we have a mystery on our hands.....
Old 07-20-2017, 04:06 PM
thunderstruck507's Avatar
If it's in good shape and you intend to use it or sell it the best bet is to send it to someone for a Cam Dr report.
Are there any other markings on it at all?
I googled pretty heavy and didn't come up with anything but this thread
Old 07-21-2017, 12:14 AM
MAG1C's Avatar
No that's all the markings .. but if you soon in you can kind of see some faded numbers on the bottom of it .I can't make them out.
Old 07-21-2017, 06:15 AM
Gearhead1's Avatar
I stand corrected.......good thing I'm not a betting man,
I would have lost money on that one. I hope you figure out what it is, now I'm curious.
Old 07-21-2017, 06:41 AM
fst100's Avatar
here's an idea, grab a sheet of tracing paper and put over that area of the cam and use a piece of black chalk and trace over the areas that are scribed on the cam and see if if you're able to get more lettering out of it.
edit-do it top and bottom because I barely see some lettering on the bottom portion of the cam.
Old 07-21-2017, 07:02 AM
fst100's Avatar
from what I can see the top portion of the cam says 53R 110+3 then the 2nd line below it says 2870H
Old 07-21-2017, 02:40 PM
tug686spd's Avatar
If I had to guess. I'm going 240/240 .588/.588. 2870h seems to be the core I've seen it from many cam vendors and the only Ls hydraulic roller lobe comp offers that ends with 53 is the specs I just listed.
Old 07-21-2017, 05:16 PM
MAG1C's Avatar
Fst100-Thanks for the help fellas ..bit no luck on the paper and black chalk.
Fst100-Yes I can read the top letter in but the bottom it has numbers that I can't even identify. So that's what I was asking for help on.
Tug686spd-im gonna just find a place here in Houston to get it measured .
Old 07-22-2017, 01:22 PM
MAG1C's Avatar
Bump!!!
Old 07-22-2017, 01:54 PM
O2Firehawk's Avatar
I would send it to Cam Dr.
Old 07-26-2017, 06:23 AM
fst100's Avatar
X2 on Cam Dr. unless you have the tools to be able to measure and read the cam profile.
Quick Reply: What cam is this ?
