LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   User Support & Resources (https://ls1tech.com/forums/user-support-resources-52/)
-   -   Can't log in with Iphone (https://ls1tech.com/forums/user-support-resources/1974665-cant-log-iphone.html)
4CamT/A Jun 4, 2024 12:04 AM
Im having trouble logging in here using my Iphone. I can log in from a tablet and a laptop but not my phone any idea where to start from? Thanks.
JeremyT Jun 4, 2024 03:12 AM
It's your username with the apostrophe. iOS marks-up the character and so it doesn't match correctly against the username/password check. This is not specific to LS1Tech but the way it handles the characters in the field boxes.
The only two options are 1) Disable the mark-up in your iOS settings or 2) Change your username to exclude the apostrophe. LS1Tech normally doesn't do username changes but maybe Administrator RPM WS6 might approve, if you want to do the username change route, since since it's a technical issue and can be a stopper.
RPM WS6 Jun 4, 2024 03:16 AM
Yes, if this is the solution then I see no problem with changing the name. :)
4CamT/A Jun 4, 2024 05:46 PM
Ok cool! Its been a few years since I've logged in with my phone.What is it that I need to do to change the name?
JeremyT Jun 5, 2024 04:55 PM
You can PM the request to either Administrator RPM WS6 or myself. If the username is available (not used) and is 20 characters or less, we can update it.
© 2026 MH Sub I, LLC dba Internet Brands
