LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   User Support & Resources (https://ls1tech.com/forums/user-support-resources-52/)
-   -   Can't search numbers??? (https://ls1tech.com/forums/user-support-resources/248303-cant-search-numbers.html)
MeanWS6 Dec 10, 2004 02:17 PM
FYI . . .I can find part numbers, but if you pump in ZL-402 (for the SLP stroker) - notta
same thing gos for just typing 402, 408, etc
Even cam specs will not work
ACW Dec 10, 2004 04:09 PM
I think it's the darn character limit set on the search indexes which is the problem... it sees the letter part (ZL) and the number part (402) separately (since they're separated by the dash and it apparently sees dashes as being equivalent to spaces) - both of which are three characters or less. Four characters apparently is the minimum length for a character-string to be indexed, so anything shorter than that will exist in the posts but not in the index of the posts which actually gets searched. Try searching for '2007' and it works, since that number is long enough... Yet try searching for 'SLP' and it's a big "no results", when you can bet 'SLP' has been mentioned a few times on here ;)
SSnakekiller Dec 10, 2004 06:06 PM
I have noticed this recently and you are right. There must be a limit set, but this was only set recently...
In the past you could search for 3 letter strings, but now you cant and I feel it should be changed back.
Like you said, what if you want to search for...
SLP, STS, LSX, ARP, 408, 427
It sux that you cant. :bang:
ACW Dec 11, 2004 05:05 AM
Y'know, Brains mentioned a couple days ago that he'd been tweaking various settings recently to try to improve performance... wonder if this was part of that! Personally I do agree with you, that's a pretty big loss of functionality for however much performance improvement :nod:
GM Muscle Dec 11, 2004 10:30 AM
Yeah I was trying to search for info on 28" tires last week and I couldn't get anything. I know I had searched for the same thing in the middle of the summer and I had gotten results.
Brains Dec 17, 2004 07:38 AM
Yup, not just a tweak -- I've rewritten the search engine packaged with vBulletin. ;) We've grown past the point the vBulletin folks feel their search is adequate, so I wrote another :lol:
ACW Dec 18, 2004 04:20 AM
Oy! Well, nobody can say you aren't earning your keep :D
© 2026 MH Sub I, LLC dba Internet Brands
