95 z28 supercharged and stroked
Year: 1995
Make: Chevrolet
Model: Camaro
Price: $12000
Mileage: 23000
Private or Dealer Listing: Private Listing
Location (State): AL
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
Random Technologies Catalytic Converter ,Hurst 6 Speed Shifter, G2 Skip Shift Eliminator, Z-Series Boost & Fuel Pressure Gauges, scan master lt1, crane cams hi-6 ignition, hypertech programmer with custom chip, competition cams 3/8 rkr 1.6 roller rockers, arizona speed and marine hpc coated headers, vortec polished sc air intake, arizona speed and marine 58mm throttle body, crane ps 92 hi-perf coil, crane model 9000-0007 didgital engine control, g2 tubular torque arm, g2 energy suspension trans brace, cnc drilled rotors, kenny brown double diamond subframe connectors, pollished alternator, strange 3.73 ring gear and pinion 7.5 10 bolt, zexel-gleason torsen traction system, gm bearing install kit 7.5 10 bolt, gm optional 10 bolt stud kit, t/a performance rearend girdle, pro shift shift light, billet specialties polished chevy breather, comp cams (.533/.560) roller cam, hotchicks front and rear susp kit hypertech power stat, optima battery, vortec 7" crank pulley, alum flywheel, slp clutch and pressure plate, koni adjustable shocks with eibach springs, g2- g-load brace, g2 adjustable panhard rod, hurst line lock. this car is worth alot more than im puttin it up for sale for but i just dont have time to drive it. the car has a few very minor issues the power door locks dont work dont know why iv never ran the car at the track so i have no time slips if interested you can call or text 256-504-5728
