| LS_10 | Jul 19, 2010 07:29 PM | S10 Carb'd LS I have a carb'd LS1 swap S10 for sale. It has run 6.90 in the 1/8 and 11.18 in the 1/4 on motor letting off just past the 1/8 marker. The truck weighs 2560lbs. With out driver i weighed 351lbs when i made those passes. Motor is really strong! I drive it on the street titled lights work. Pretty much stock bottom end ARP rod bolts, Arp head studs, T-Rex cam, extremely worked heads, Vic.jr. intake, AED 750HO-HP carb, MSD-6010 box, autometer guages, TCI SFI flexplate, 3800 nitrous converter with anti balloning plate, Built TH-400 trans, headers, exhaust to the axle dumped, Ford 9in. spool 5.13's, 9 way adjustable rear shocks, big bullet proof drive shaft made for truck, race seats, shift light, Weld pro star's, 275/60/15 mt dr's, skinies in front, battery and fuel cell in bed, Flex a lite dual fans, no over heating issues at all. Cold start drivabilty is very impressive pump the gas once fire it and go never has it ever died once it started on a cold start. or any start for that matter. put it on the dyno it made 385 to the wheels with very little timing in the motor. tuned in it should make close to 420 to the wheels with this drivetrain in a 6 speed F-body would probably make near 460-480 to the wheels. everything was new except the pistons rods and crank new bearings and rings tho doesn't smoke at all!!! asking $6000 http://www.youtube.com/watch?v=skx0vDYEpIs http://www.youtube.com/watch?v=9FaYG...eature=related |
