WS6 vert turbo 511 rwhp
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $19000
Mileage: 59000
Private or Dealer Listing: Private Listing
Location (State): MN
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
I believe 1 of 74 triple black 6-speed convertibles made in the last year of for the TA in 2002.
59,000 miles good paint and interior.
The turbo spool and blowoff valve noise is amazing. Everything works as it should from the factory and has a lot of power and torque.
Have 15k in aftermarket goodies.
Rebuilt stage 2+ T-56 by The Gear Box with Timken bearings good to 750hp
STS Turbo Kit new style kit w/ intercooler and blowoff valve(still under warranty)
Autometer guages: Air/Fuel ratio, Boost psi, & Fuel Pressure
Upgraded 67mm Turbo with oil pump failure alarm
Methanol Injection system with knock sensor warning alarm
Electronic boost controller w/ in dash switches (Set for 5psi low and 8psi high)
New Monster stage 3 clutch good to 750rwhp!
60 lb injectors
Walbro fuel pump
Tick master cylinder
6pt bolt in wolfe cage w/ swingouts (easily removable)
HP Tuners Pro
Lou's short throw shifter
Custom dynotune by Straightline Performance (1320hp.com) currently producing 480rwhp and 540rwt on pump gas w/ a very safe conservative tune at 13 degrees of timing. The car made 511rwhp and 556rwt when the timing was bumped up 3 degees on the dyno at 8lbs of boost
Extra set of ls2 ported heads. This will lower compression by a point so you could run 12-14 lbs of boost and make some serious #'s
email raiderchad@live.com for pics or questions
