*** 1999 Firehawk Formula 1 of 18. heads cam
Year: 1999
Make: Pontiac
Model: Firebird
Price: $17000
Mileage: 54000
Private or Dealer Listing: Private Listing
Location (State): WI
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
1999 Pontiac Formula Firehawk
1 of 18 built
54k miles
Drivetrain:
comp cam 228/228 dur. 571/571 lift, 114 lsa
Patriot 5.3l heads
LS6 intake
kooks long tube headers
magnaflow catted y-pipe
GMMG exhaust
28 lb injectors
polished maf
160 stat
ngk tr 55 plugs
msd 8.5 mm wires
spec 3 clutch and new fly wheel
mgw short shifter.
factory auburn posi rear end
stock 3.42 gears
eibach springs 1.5 drop
re valved bilstein shocks ( + 10% low speed rebound, + 20% high speed rebound, stock bump)
sub frame connectors
BMR adj, torque arm
Umi Adj torque are relocation bracket
lower control arm relocation brackets
boxed lower control arms
BMR solid sway bars
poly bushing everywhere
pan hard bar
silver faced firehawk gauges
boyd coddington 18" polished wheels
285/35-18 front
26 12.00 18 mickey thompson DR
slotted rotors
polished calipers
polished accs under hood and other little things
i'm sure im forgetting somethings.
Tuned by : West bend dyno 428 whp and 420 wtq on a mustang dyno
gets 28 mpg on the interstate running 75-80 mph
1 of 18 built
54k miles
Drivetrain:
Patriot 5.3l heads
LS6 intake
GMMG exhaust
28 lb injectors
polished maf
160 stat
ngk tr 55 plugs
msd 8.5 mm wires
mgw short shifter.
stock 3.42 gears
BMR adj, torque arm
BMR solid sway bars
pan hard bar
285/35-18 front
slotted rotors
polished calipers
