90 Mustang notch FHP Single Turbo
Year: 1990
Make: Ford
Model: Mustang
Price: $9500
Mileage: 1
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Gray
LS Engine?: Car has LS engine
List of mods:
1990 Mustang Coupe (Highway patrol car)
*Bottom end
306ci stroker (all work done @ LPM in Cocoa FL)
Probe Dish pistons/pins
Plasma Moly rings
Std. Clev. Rod bearings
Std. King Main bearings
Eagle h-bean rods
Main Gridle
Polsish crank
Moroso oil pan
Cometic head gaskets
Melling select oil pump/hard oil pump drive
Double roller timing chain/gear
dum
*Head
Ported/Polished
E-303 camshaft
Ford motorsports lifters
Viton valves seals
5 angle valve job
Ford racing valve covers
Cartech intake
dum
*Cooling
Jegs electrical single fan
Electric water pump
dum
*Rear End
3:55 gear
31 splin axels
locker
dum
*Transmission/clutch
New clutch cable
Freshly rebuild T5 transmission
Pro 5.0 short shifter
King cobra clutch/new 3 pc clutch quad kit
dum
*Ignition
Full MSD 6 Series ignition
Msd pro billet distributor
TFI coil
jegs coil wires
dum
*Computer/tunning
SCT 4 program/ 4 bank chip
Fully tuned @ 9lbs it puts down 450whp
dum
*Turbo kit
Custom Single Turbo kit
Holset HX40G turbo
Custom 4" downpipe
Tial old school wastegate
Turbo blanket
Evrything is powder coated
dum
*Fuel system
Accufab fuel pressure regulator
Walbro 255 in tank
Terex pusher pump
42lb injectors
dum
*Suspension
Full UPR front suspension
upr k-memeber
upr coilovers
ups caster/camber plates
rear suspension has HPM lower control arms
dum
*Wheels/Tires
Weld draglites wheels
Nittos drag radials
dum
There is stuff that im missing, but you get the idea, car is built the right way... runs like a beast, is definately a must see. NO JOY RIDES, text only if interested with cash in hand.... 904 402 0433
dum
Ps. Car went 10.9x @ 129mph @ 10-11lbs of boost w shitty nittos
I don't know how to post pics here from my iPad but I got plenty of pics in my phone, OR CHECK MY ALBUM HERE http://s1055.photobucket.com/albums/s512/knarias/
Stock can't handle much, I reinforced synchros and did a full overhaul, it will handle the current power but eventually a tko600 or a built c4 w trans brake were my plans. Idk how much would it be to have it shipped, I can make a few calls to get u a quote or u can do it it urself, is up to u bud, it should be that much tho, we shipped my brothers civic a year ago to NC w a local company and I think it was like .75 a mile if I remember right...
Internals are made to handle 800-1000, block is a stock 2 main block, it has the main gridle done so it gives a bit of extra strength so I would say 550-600, after that u asking for trouble, a bare 306 dart block goes for 1800-2500, swap internals and sky is the limit...
Ttt we made a few adjustments on the map since weather is changing here in north Fl + fixed a lil exhaust leak and now puts down 502rwhp 598tq @ the same boost level 11psi...
pictures of interior? how is the paint? overall condition of the car? engine bay looks real clean....mileage on car/motor? when were all these upgrades done? number of owners?
located in fl
located in fl
