1989 Volvo 245 Wagon Turbo 5.3/T56/8.8 No idea what the car is making, but a buddy with a similar setup made 46x/6xx on 10lbs on 93 only. Car is still on pump gas at the moment. The car has dings, some scratches, roof and hood are fading and starting to show some awesome patina. It's by no means perfect, but washes up pretty good. $13,000 as it sits (all spare parts included) $12,000 without Welds (general 17x7 steelies in the rear) 1989 Volvo 245 - 99% Rust Free 23x,xxx miles 3120 lbs As it sits Appears to have been involved in 2 accidents in it's life. Both have been fixed at some point. *Front passenger side headlight support *Rear driver 1/4 panel *No A/C *Heater core and blower have been removed. Never intended to have A/C again, and being in Texas heat is really not a big deal. ***Car is registered Antique in Texas. Has no problem passing safety requirements as everything works, but probably won't pass emissions (if your state has them) due to the open downpipe. Engine Handbuilt poly mounts Notched K factory k member Pre 2004 5.3 LM7 (roughly 100k miles) 706 Heads LS1 cam Standard beehive springs (not sure what lift they are) ARP Rod Bolts ARP Head Studs (new) Shimmed ls1 oil pump (makes 80+psi on the top end) Fbody oil pickup tube (new) Fbody windage tray (new) Fbody oil pan -10an welded bung Fbody intake Fbody DBC throttle body Fbody Water pump PSC High pressure power steering pump PCS removable aluminum pulley Turnkey power steering pump mount -6AN power steering feed line -6AN power steering return line NGK BR7EF 900 series NA radiator - Notched top shroud, pushed all the way forward LS1 Lokar throttle cable kit Lincoln Mark VIII fan on heavy Duty 85amp relay Turbo setup Turbonetics T72 (3kish miles) Flipped truck manifolds (No EGR) Hand built 2.5" y pipe 1/2" t4 flange 2.5" OBX V band flanges $150 Ebay intercooler 31x12x4 (same one a lot of guys on here run) T bolt clamps OBX universal cold side PTP Turbo Blanket -10AN braided return line -3AN feed line Entire hotside coated and wrapped (not professionally) JGS 44mm Wastegate (Open dump) JGS 60mm BOV (100% atmosphere) 3.5" OBX V band Hand built (reworked truck) 3" down pipe (open) Drivetrain M12 T56 GTO 6 speed Modified AW70 mount Monster Stage 3 clutch (good to like 650whp IIRC) MGW Fbody shifter (Tailshaft has Fbody guts) -3An braided clutch line Wilwood 3/4 Clutch MC Texas Drivetrain Specialists 3" Aluminum Shaft Spicer hybrid U Joints Fuel DW 300 -6AN Fragola Feed line (hard line under car) -6AN Fragola Return line (hard line under car) FAST Fuel Rails 60 lb Siemen Deka Injectors Fuel Labs Boost Reference AFRP Earls 40micron -6AN fuel filter Rear end Ford Exploder 8.8 Narrowed 2 15/16" 3.73 ring & pinion Factory locker All new National bearings minus pinion (no junk) Volvo brackets New brakes Custom lines to Volvo proportioning valve Suspension IPD Blue Springs 1 coil cut out of the rear Unknown struts HD shocks IPD Adjustable Panhard IPD Poly Trailing Arm bushings IPD Poly Torque arm bushings Wheels/brakes 17x8 +38 ESM BBS LM Replicas 17x9 6.5" BS Weld RTS 255/40/17 Nitto NT05's IPD 25mm spacers Brembo Rotors IPD brake pads Interior/Electronics Red Corbeau Cr1 (It's not a wide seat) Corbeau 240 series mounting bracket 2002 Sierra PCM Badass laser cut PCM mount Pre 2004 Truck Harness thinned and flipped AEM Uego Wideband 3 3/8" Autometer Tach (mounted where factory big clock was) 2 1/16" Autometer Boost/Vac Gauge 2 1/16" Aeroforce Interceptor with oil presure sending unit Running SD currently - 3 BAR map sensor IAT gauge in coldside What the car needs: Tune could be smoothed out, but it makes great power. Just needs to be mapped and VE tables adjusted Pinion bearing is making noise & leaks a bit sometimes No speedometer (after rear end swap) I'm not going to post a bunch of pictures, I'll just link to the build thread. http://forums.turbobricks.com/showthread.php?t=266235 https://scontent-b-dfw.xx.fbcdn.net/...66263765_n.jpg https://scontent-a-dfw.xx.fbcdn.net/...51434683_n.jpg |
this thing is Awesome |
New expansion tank New door jam switches New dash bulbs New window switches (old were finicky) Currently no washer pump/resevoir in the car (stock is big and ugly). Going to retrofit something smaller under the fender at some point. |
Id like to make an offer, please text 219 588 5164 |
did it ever sell |
No it didnt, trying to do decide wether he wants to do e85 on it. |
Still for sale Did this LSx Volvo wagon ever sell? |
$12k with the steelie setup. $13k with the RTS setup. Car has a low mile TRW rack in it now -New inner/outer tie rods -IPD 25mm swaybars front/rear -Poly sway bushings -5x114.3 hubs included (uninstalled) Only selling because I want to start on the next build/finish my truck. |
Trades? |
Would rather not at the moment, unless it's something really cool. |
Its no where near as cool as a LS turbo Volvo wagon for sure. But I like it alright lol. 05 GTO 66K miles...cam, converter and some nitrous. |
PM pics on the RTS, or does it need the other hubs installed for them? |
Built the 5x114.3 hubs to swap the front, just haven't got around to it yet. Still running 5x108 Volvo wheels in the front. 17x9 6.5BS on 255/40/17 Nt05's (pretty much the limit unless you want to tub or pull the 1/4 panels out). Exhaust is a stubby now and doesn't exit under the passenger side bumper any more. https://fbcdn-sphotos-f-a.akamaihd.n...91123048_n.jpg |
Any more recent photos interior and out? The OP all the photos are dead. |
Bump. Starting a new build, time for someone else to enjoy a swap you will likely never see. https://scontent-a-dfw.xx.fbcdn.net/...9c&oe=5491D5BF https://fbcdn-sphotos-b-a.akamaihd.n...99e75cee4cb8fa With the old wheels and roof rack https://scontent-b-dfw.xx.fbcdn.net/...21&oe=5490B29A |
So much want |
I'm in love with this thing man oh man |
back up for sale. $11k as is. Car has mint black interior now (including driver seat) $10k I'll throw some steelies on it and keep the Welds. Might be interested in a trade. Looking to get back into a Rubicon (preferably 2004-2006). Or a nice LS DD maybe. https://fbcdn-sphotos-c-a.akamaihd.n...99368667_o.jpg https://fbcdn-sphotos-e-a.akamaihd.n...45334608_o.jpg https://scontent-dfw.xx.fbcdn.net/hp...b8&oe=557F23BF |
This thing is so sick. wanted last time you put for sale. Don't want to ruin it up in the rust belt though, too unique. |
© 2024 MH Sub I, LLC dba Internet Brands
