1965 Mustang GT Resto-Mod *PA*
Year: 1965
Make: Ford
Model: Mustang
Price: $47900
Mileage: 264
Private or Dealer Listing: Private Listing
Location (State): PA
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has other engine
Engine
-302 V8 bored .40 over
-flat top pistons
-512/496 Edelbrock performance cam
-69 cast iron heads with 202 valves 160 exhaust
-650 Holley double pumper carb
-MSD pro distributor
-MSD coil
-Moroso water pump
-Hv Oil pump
-Stainless steel dipstick
-ARP stainless steel bolt kit
-Summit Racing aluminum valve covers
-Summit Racing 100 amp alternator
-Spiro pro wires
-MSD blaster TFI coils
-Underdrive pulleys with V belt
-Thermostat housing
-3 row radiator
-Hedman 1 5/8" street headers
Transmission
-Ford Racing SuperDuty t-5 with 28 spline output
-Short throw shifter
-Hurst 8" chrome stick
-Hurst T-shifter
-Bellhousing spacer plate (6 bolt)
-Hays 30lb billet flywheel
-ARP flywheel bolts
-ARP pressure plate bolts
-RAM powergrip Heavy duty clutch set
Rear
-Completly stripped/shortened/bead blasted 9" posi rear
-Moser Ford Torino ends
-Moser 31 spline axles with bearings and 1/2" studs
-Detroit locker
-3.55 Ring and pinion
-1350 pinion yoke
-Complete bearing and seal kit
-Driveshaft oil pump
Suspension/Brakes
-Calvert Cal trac bars
-Misc brake lines & bearings from BC Auto
-Wilwood Big brake kit with drilled and slotted rotors
-Wilwood Rear pro street kit with parking brake & drilled/slotted rotors
-Wilwood polished master 1" bore
-Wilwood billet prop valve
-Rear brake hoses
-20 ball joint
-Strut rod bushing's
-New tie rod's
Body
-All body panels are brand new, not bondo.
-Complete front bumper kit
-Original California tint glass
-Windshield wiper bezel & nut kit
-Vent window assembly Left and right side
-Brand new window molding and clips
-Door latch striker plate
-Door handle kit
-New Deck lid hatch
-New windshield weatherstrip
-New roof rail weatherstrip
-New door weatherstrip
-New rear window weatherstrip
-New decklid weatherstrip
-New hood to cowl weatherstrip
Interior
-4 yard's of Custom Laytex black
-Electric remote trunk release kit
-Door window regulator's
-Door/Quarter window roller set
-Complete upholstery (Palomino coupe)
-Headliner (Saddle coupe)
-Trunk mat rubber
-Door panels pair (Palomino)
-Windlace 16 feet brown carpet
-Headliner pillar trim retainer's
-Sill plate
-Seat track kit
-Sunvisor bracket
-Tinted rear view mirror
Wheels
-American Racing 18x7
-Falken summer tires 245/30/18?
I'm sure some things were left out but you get the idea. Cash is king but accepting muscle cars of lower value plus cash on your end.
Call or text 267-394-0087
I can email more pictures upon request.
