1996 formula ws6 nitrous
Year: 1996
Make: Pontiac
Model: Trans Am
Price: $5550
Mileage: 76000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
Below is a video of a startup walk around and it running 11.4@121 at the track. Please text me if you are interested! Priced to sell!!! elynchttu@gmail.com or 214-621-0586
Someone asked me for a list of mods so I thought I would post for everyone to see. There is probably more but this is what I came up with:
engine:
Eagle 4340 crank
Eagle H-beam rods
wiseco 2618 pistons
4-bolt splayed main caps
58mm Edelbrock TB
Pacesetter longtubes
Pacesetter offroad y-pipe
custom exhaust after y-pipe
1.6 comp cam pro mag roller rockers
PAC 918 valvesprings
hardened pushrods with guideplates
230/230 107 LSA ~.6/.6" lift cam (LE3.2 cam)
double roller timing set (Cloyes i think but could be a GMPP part too, been a while)
ported stock heads by Lloyd Elliot
AC delete pulley
removed AC
removed AIR
removed EGR
TB bypass mod
Dynotune by Moe Bailey
Opti replaced ~5k miles ago
255 lph walbro with voltage boost kit installed
MSD 6AL ignition box with 2 step installed on custom shifter button
mezierre electric water pump
drivetrain and suspension:
BMR tubular subframe connectors (weld-in)
BMR tubular lower control arms
Edelbrock torque arm
driveshaft safety loop
removed front and rear sway bars
airbag in right rear spring for launching
I have a tubular panhard rod, never installed, missing one piece
Moser 12 bolt with spool and 4.10 gears
transmission was rebuilt 30k miles ago with viper shift fork and new syncros at a shop
SPEC stage 2 kevlar clutch - still holds strong
Nitrous:
This install I do have full receipts for
Nitrous outlet installed it all
Nitrous outlet plate kit
Nitrous outlet bottle with dash for bottle heater, purge and arm.
Nitrous outlet controller for WOT switch, window switch, gear lockout, progressive opening of solenoids, etc. Controller is in glovebox
I am sure there is more but this is all I can think of today.
engine:
Eagle 4340 crank
Eagle H-beam rods
wiseco 2618 pistons
58mm Edelbrock TB
AC delete pulley
removed AC
removed AIR
removed EGR
TB bypass mod
Nitrous:
