WTT BBC F3 Direct drive Pro-charged engine complete
Year: 2016
Make: Chevrolet
Model: Bel Air
Price: $25000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Black
540" BBC Dart block, Callies Magnum crank, Callies Billet rods, CP pistons, Stef's pan, Belt drive, Fluid dampener, MSD crank trigger and Distributor, Pro Topline 360 cnc heads with T&D Shaft mount rockers, Billet Atomizer 225lb injectors, Wilson elbow and Wilson 105mm throttle body, Pro Charger Direct Drive F3X 135
Motor is in shop right now just getting a freshen up. So it will be ready to start the new year for you.
If you want to go Very fast and be in the front with the heavy hitters this is the engine for you. BIG HORSE POWER set up..
Patrick Barnhill is the Tuner of this engine as well..
Motor comes complete READY to drop in, 105mm Wilson throttle body to Stef's oil pan, Procharger F3X direct drive blower to flywheel, With front mount fuel pump. Electronics used on this motor were BS3 MSD Grid Not included.. Also motor was bolted into car using Front plate and Mid plate also NOT included stayed with car.
Their are plenty of video's of this car and set-up running on you tube. This was a Grudge motor and ran with the top guys in Grudge racing.
$25k cash Trade Higher
Whatcha got? you can text me pics and info 219-37eight- 8 three three 2
It has more HP than you hows that! Made over 1900 on 18 psi. and I run it at 34. Hows that smart ***! And Grudge racing is where the money is at.. 5-10k races all day everyday!!
LS powered cars. Ram air, Camaro, Vette, Whatever really. Something with some value and or cash my way unless its a newer vette then I can add cash for right deal.
