2004 Built 408 Stroker GTO
Year: 2004
Make: Pontiac
Model: GTO
Price: $13500
Mileage: 71000
Private or Dealer Listing: Private Listing
Location (State): AL
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
71k miles on the body and 3500 on Built Motor
Built 408 stroker motor- all parts from Texas speed except for head work. Forged motor built to handle 200-300 shot of nitrous. Over $8500 in the engine alone.
No nitrous has been installed or ran on the motor. Car made 508/460 all motor on a speed density tune.
Below are a list of the parts used:
ARP Manifold, Flywheel pressure plate and throttle body bolts. ARP Head Stud Kit
Tick Performance Master Cylinder
Tick Performance Slave bleeder line
Lunati Forged Crankshaft
Lunati 6.125" H-Beam w/ ARP Rod Bolts
Wiseco 4.03" -3.0cc Flat-Top
King Main and Rod Bearings
LSX Rear Main Seal,Front Crankshaft seal
Melling High Pressure Oil Pump
LS2 Lifter Tray with LS7 Lifters
LS6 rocker Arms
Nick Williams 102mm Throttle Body
LS3 intake Manifold- Port and Polish-$1800
ASP Crank Pulley
FAST 50 lb Injectors
Lingenfelter High Flow fuel pump kit
American Racing Longtube Headers& offroad xpipe($1200)
Large Custom Grind Cam
GM Slave Cylinder
Spec Stage 3 plus Clutch
RAM Flywheel
Aluminum Drive Shaft
$500 Rip shifter short shifter(Best available)
Over the radiator intake, large custom grind cam.
Brand new Nitto 555r tires.
***I have receipts for almost everything- I have 8k plus in receipts and thats not including tires, and a lot of small items I'm sure I am leaving out.
Black leather interior.
Hate to sell, but I am married with a small child and don't have enough time for the car.
**The car was tuned on a speed density tune(No MAF) It could use some fine tuning to make more power and also work out some of the cam surge/idle surge. I drove the car on a 400 mile trip with no problems recenlty.**
*PM me if you would like a clip of the car idling**
consider a trade plus some cash on my end?
-1996 LT1/T-56 from firebird formula donor car
-10 bolt 3.42 rear end from fourth gen f-body
-New C5 Corvette front brakes
-Adjustable wilwood proportioning valve
-New fourth gen F-body master cylinder
-MGW short throw shifter
-C5 Corvette wagon wheels w/ 275 rears and 245 fronts
-Adjustable weight jacks with 825 lb front springs, 125 lb rears
-Koni yellow shocks
-Adjustable strut mounts
-8 point roll bar
-Sparco Sprint V bucket seats
-Crow 3" 5 pt harnesses
-Sparco steering wheel/shift ****
-Fourth gen. F-body pedals/clutch hydraulics
-Full set of autometer ultralight electric gauges
-Dyno Don's ceramic coated short length headers
-Stainless Borla catback with electric exhaust cutout
-Lower control arm relocation brackets
-UMI Adjustable panhard bar
-Spohn lower control arms
-Complete spohn front end steering rebuild
-Quick ratio steering box
-Braided stainless steel fuel lines
-New fuel sending unit and Walbro pump
-Optima red top battery
-New trans, clutch, fly wheel and slave cylinder
-Koni yellow shocks
-8 point roll bar
