1998 S-10 LS 5.3, 4L60, Runs Great 4 Attachment(s) 1998 S-10 with a 5.3L, 4l60 trans, 10 bolt rear with 342 posi. Truck has conversion oil pan, aluminum radiator, dual fans, shorty header, new water pump, Ac compressor, just needs the lines to be installed and charged. I have the lines and all fittings. New shocks front and rear. Transmission was rebuilt and new convertor. Not even 500 miles on all the parts. the motor had 58k on it. Truck also comes with American Racing Torque Thrusts with BFG's. Everything on the dash works, all factory gauges, not lights on, check engine light works. There is a bed liner. The Body has some dings and dents, No Rot. Interior needs a good cleaning. Im driving it now and just used it to drop off my Trans for my Turbo S-10. 22MPG at 80 on the HWY. Truck runs Flawless. Just have way to many cars. Im sure I'm missing something $6500.00 neg Thanks 516-528-6374 Cell |
Do you have any videos of the truck running with interior etc in it? thanks alot |
does it pass inspection in ny? if so, how? |
Passed NY Inspection. They scanned the reg and plugged in the ob2. No codes, Check engine light works. Everything is wire correct and fall factory lights and gauges work. |
© 2024 MH Sub I, LLC dba Internet Brands
