03/04 swapped kenne bell cobra, fully built in NC
Year: 1997
Make: Ford
Model: Mustang
Price: $19000
Mileage: 39000
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Green
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
feel free to pm me, respond here, text or email
here are some pics and the parts list- if you need any additional pics of vids etc just ask.
The only bad thing about the car are it has the normal highway use chips and it needs new tires- the front and rears are just old, I don't drive it much so it just sits. I drove it 5 hours round trip last week with zero issues, but as far as rear traction is concerned- they're not up to it at all. hence why I don't have definative numbers on the car. I DO have a graph of it pulling to 5000 rpm before the tires were spinning on the mustang dyno and it was making 600/570 on pump93oct, 15 degrees of timing and 14.5psi. The car is pullied for 17psi. But please don't let that put you off if you are serious about the car- if numbers are the only thing holding you back, then contact me and maybe we can work something out- I'm just done with messing with the car for it to just sit.
Now for the parts list:
Engine Modifications:
Windsor Iron Block fully machined, .010” bored 400 grit cylinder finish
ROSS custom pistons -6.5cc dish with valve reliefs, 10:1 CR
H13 tool steel wrist pins .200 wall thickness
ARP 9mm main side bolts
King HP .010 undersize main bearings
Kings HP .010 undersize rod bearings
03/04 Mach 1 heads, hot tanked, decked, fresh valve job
VITON valve stem seals
Total Seal AP stainless rings 3.562”
SVT Manley rods w/ARP 2000 rod bolts
Forged cobra 8 bolt crank polished, each journal custom turned, w/custom rekeyed snout
2003 mustang cobra harmonic balancer
Metco interchangeable crank pulley kit with 2# lower
ARP harmonic balancer bolt
ARP main studs
Custom PAC valvesprings and stock retainers 125lb seat pressure open/105 lb at .475 lift
FRPP lifters and rollers
ARP head studs
Bullet cams custom grind 235/238 @ .050” duration, .475”/.480”lift with custom keyways degree’d in at 111/118
ARP camshaft bolts
FRPP GT500 secondary timing chains
FRPP timing chain set and tensioners
Trick Flow adjustable crank gears and billet spacer
03/04 cobra crank trigger wheel
Cloyes adjustable intake cam gears
Accufab polished 03/04 single blade throttle body
Frpp gaskets and seals (heads, front cover, valve covers, oil pan, intake)
Ford H.O. oil pump w/pickup
97 cobra oil windage tray clearanced for Windsor block.
97 cobra oil pan
Ford oem COP’s
theRedMonster COP wiring harness
redfire powder coated COP valve covers
NGK TR6 plugs 0.28” gap
Moroso breather catch can -8an inlet, ball outlet
Fragola -8an fittings and hose from passenger and driver side valve covers to catch can
SCT BA2600 MAF
JLT RAI w/12” air filter
Battery relocated to trunk with summit battery box
Moroso battery kill switch
Kenne bell boost a spark
97’ cobra wiring harness modified for iat2, iac, and tps locations
Exhaust Modifications:
Kooks 1 ¾” x 3” stainless headers
Kooks 3”x 2.5” stainless O/R mid pipe w/4 o2 bungs welded in
Magnaflow mufflers with chrome turndowns
EGR and SAI delete
Relocated exhaust hangers
Cooling Modifications:
Stewarts H.O. water pump
165* thermostat
Modularspeed coolant crossover delete, anodized black with coolant sensors
Billet aluminum tstat housing anodized black
Driver side head coolant bypass mod
Ron Davis custom aluminum racing radiator-relocated
Complete A/C system delete w/frpp delete pulley
07+ GT500 coolant expansion tank, no coolant sensor
Stock 4.6L 97’ cobra radiator fan
-10an coolant lines and fittings
-6an coolant bypass mod line and fittings
Bosch intercooler pump
Fluidyne 3 core heat exchanger
2003 mustang cobra intercooler
Power Adder:
Kenne Bell 2.6H supercharger
4” upper pulley
3.75” upper pulley
Drivetrain Modifications:
theT45source.com fully built billet/carbon fiber 26-spline input T45 transmission
SPEC steel flywheel
SPEC Stage 3+ clutch w/ SPEC pressure plate
SPEC throw-out and pilot bearing
ARP flywheel bolts
Steeda Tri-ax shifter
FRPP 31-spline rear differential with carbon fiber clutches
Moser 31-spline rear axles
FRPP 3.73 rear gear ratio
FRPP 3.73 speedometer sender gear for T45 transmission
New 8.8” bearings and seals
Chrome 8.8” rear differential cover
Moroso front wheel studs
ARP 3.5” wheel studs
FRPP FR500 stainless lug nuts
PA performance high torque starter
Fuel Modifications:
Glenn’s Performance 94-97 sumped 16 gal. fuel tank -10an outlet -6an return
Aeromotive adjustable bypass fuel regulator
Division X 03/04 cobra fuel rails
Division X FRPS delete plate
Glenn’s Performance -10an 100 micron fuel filter
Weldon 1100-A fuel pump
FRPP 80 lb/hr Ev1 fuel injectors
Painless fuel pump wiring/relay
Fragola push lock fittings
Fragola -an fittings
Fragola 8000 -6an return line
Fragola 8000 -8an pump to rails line
Fragola 8000 -10an feed line
Summit racing in tank filtered roll over valve
Suspension Modifications:
Eibach front and rear sway bars and bushings
H&R race springs-no isolators or dampners
Bilstein HD struts and shocks
Stang suspension C/C plates
Steeda X2 ball joints
Stang Suspension adjustable rear LCAs
H&R bump stop
Poly-urethane offset steering rack bushings
Maximum Motorsports welded full length SFC
AJE tubular transmission cross-member
Roush/Alcon four piston front calipers non-floating
Baer 14” two piece drilled/slotted directional front rotors
Baer 13” slotted directional rear rotors
Gt rear mustang over-axle brake caliper bracket
Stang Suspension bump-steer kit
Energy suspension poly-urethane motor mounts
½” rear wheel spacers
Eastwood rolled rear fenders
Interior Modifications:
2003 mustang cobra front and rear seats
UPR billet interior accessories
Billet door locks
Billet 5 speed shifter ****
Billet door seal SVT plates
Bullet pedal covers
Black carpet
Scott fab black aluminum trunk floor panels
Autometer electric fuel pressure cobalt series
Autometer electric boost gauge cobalt series
Autometer digital A/F wideband gauge cobalt series
(2) Aeroforce Interceptor Scan gauges
Oil pressure analog sender for Aeroforce Interceptor
Blue LED dash and HVAC gauge lights
3 pod pillar gauge holder
Autometer dash dual gauge pod
Raceline 5-point driver and passenger safety harnesses
Maximum Motorsports 6 pt. bolt-in cage with removable harness bar and swinging door bars
Exterior Modifications:
Saleen S-281 wing
FR500 stealth black 18x9 front wheels
BFG KDW1 front tires
FR500 stealth black 18x10 rear wheels
BFG KDW2 rear tires
Smoked front headlights
Tuning:
SCT Pro Racer Package Tuning Software Advantage III
SCT XCAL 3 handheld tuner
SCT Live Link datalogging software
EEC analyzer software
Firefold fire wire interface from wideband to XCAL 3
again I am asking for $19K for the car.
ARP main studs
ARP head studs
ARP camshaft bolts
97 cobra oil pan
Ford oem COP’s
SCT BA2600 MAF
EGR and SAI delete
165* thermostat
Power Adder:
4” upper pulley
3.75” upper pulley
SPEC steel flywheel
ARP flywheel bolts
Fuel Modifications:
H&R bump stop
Billet door locks
Bullet pedal covers
Black carpet
Saleen S-281 wing
BFG KDW2 rear tires
Tuning:
Amazing looking ride. Just a little out of my price range i'm afraid. Who did your engine work if I may ask? I'm in Asheville and recognized the Sonic parking lot there. Good luck on the sell
I did my own engine work under the guidance of Dez racing's (boston Mass) main engine builder. I like to learn everything that I can. thanks for the compliments. I may take it to the next c&c at kia
here's a walk around vid- from cold start until it settles for idle with 30 sec left on the vid
https://flic.kr/p/rR79xd
