THADD | 06-23-2015 11:35 AM | For sale as a roller or turn key. $18,000 obo as a roller Very nice clean car, the whole car was stripped and re wired and has working headlights tailights, power windows. Has a pin on VFN hood, Weld wheels on radials front and rear, 10 pt certified cage, Kirkey seat with cover, lightweight carpet, stock dash and door panels, oil, boost, tach, shift light, volt gauges, ALL Spohn chromoly solid end suspension. Brand new double adjustable Afco front and rear, brand new TRZ anti roll, Speed glass front and rear, Spohn tubular k member, Aerospace drag brakes front and rear, subframe connectors, 12 bolt Moser with spool, 33 spline, 411 gears, fuel cell, brand new Holley ecu, already wired up, Leash boost controller and bump box with co2 bottle, lightweight steering column with removable wheel, 5 pt harness, 16 volt system battery in the trunk, travel limiters, power glide shifter, Magnafuel fuel pump with -10 lines to engine bay, parachute. I'm sure I'm forgetting something. This is a low 5 second car and I will sell turn key for $28,000 OBO. Turn key will include everything above plus a fresh built 347, aftermarket 225cc heads, 76 mm turbo with a/w inter cooler set up, Aftermarket case roller tail shaft power glide built by Mike Graham at VA Speed, PTC custom converter all fresh for this season and no passes made. I might consider trades on a Very nice Vette or a Very nice pontoon and cash my way https://cimg9.ibsrv.net/gimg/ls1tech...fadb307482.jpg https://cimg8.ibsrv.net/gimg/ls1tech...d8a5d8bb96.jpg https://cimg0.ibsrv.net/gimg/ls1tech...b0ebfeb9a3.jpg https://cimg1.ibsrv.net/gimg/ls1tech...8bb2c82ec0.jpg |
