Built 1998 Trans Am LQ9 Stroker 408 5 Attachment(s) 1998 Pontiac Transam race car White on beige tan leather interior T tops Street legal ENGINE: HKE 408 Stroker Wiseco Pistons 4.030 Bore With Coated Skirts Scat H beam rods 6.125" Eagle Forged 4.00 Crank Arp Main Studs Arp Rod Bolts HPE "Big E" Camshaft 244/248 612/615 Ona 115 Lsa Trick Flow Hardened Pushrods Yella Terra Ultra-Light Shaft Mounted Rocker Arms GM LS7 Lifters GM MLS Head Gaskets ARP Head Studs Double Roller Timing Chain Shimmed LS6 Oil Pump Assembly Fully Assembled Total Engine Airflow 235 Cc Trick Flow Cathedral Port Heads Fast 92 MM Intake Manifold REV Extreme 100MM Throttle Body SLP GM 85mm Mass Airflow Sensor Fast Toys 90MM Air Lid K&N Filter Kooks 1 7/8 Headers Stepped To 2" With 3.5" Collectors LMR Custom Mandrel Bent 3.5 Inch Exhaust From Headers Back Flowmaster True Y Collector Borla Xr-1 Stainless Muffler ASP Racing Under Drive Crank Pulley Mezeire Electric Water Pump Walbro 225 In Tank Fuel Pump Bosch Inline Auxiliary Fuel Pump FMS SVO 30# Injectors More CHASSIS AND SUSPENSION: BMR Tubular K Member BMR Tubular Adjustable Lower Control Arms BMR Trak Pak Adjustable Torque Arm Setup BMR Adjustable Panhard Bar BMR Boxed Weld In Sub Frame Connectors QA1 Adjustable Shocks And Coli Over In Front Eibach Pro Kit Springs In Rear Energy Suspension Trans Mount Prothane Engine Mounts Edlebrock Boxed Lower Control Arms Rear Upgraded Brake Rotors And Pads SLP Line Lock Custom Switch Panel For Nitrous And Line Lock More POWER ADDER: Custom Hard Lined 6 Solenoid Nitrous Setup 2 NOS Fuel Solenoids 2 NOS Nitrous Solenoids 2 Small Powershot Purge Solenoids WOT Switch ZEX TPS Switch MSD Adjustable Window Switch Nitro Dave's Low/High Pressure Auxiliary Fuel System Areomotive Adjustable Fuel Pressure Regulator More DRIVETRAIN: Fully Built TH400 Reverse Manual Valve Body Speed Sender Tail Shaft Conversion BMR Conversion Cross Member Vigilante Torque Converter 2800 RMS Stall Speed Auxiliary Trans Cooler Valvoline Racing Synthetic Fluid Upgraded U Joints Inland Empire Aluminum Driveshaft Fully Built Rear Differential 3.73 Motiv Gear Set Upgraded Axles Ta Differential Cover / Girdle Weld Drag Lights 15x3.5 And 15x8 MT ET Radial 275/50/15 More SOUND: Pioneer Single Din Bluetooth Cd Player With Mp3 Capability JL Audio Front Component Speaker Set With Crossover And Tweeters Polk Momo Series Rear Seat Speakers Polk Momo Series Rear Hatch Speakers |
ttt up top for hke |
Trade Trade for GTO with 408 and built T56, one pc aluminum drive shaft? 4k on drive line... |
Originally Posted by 1-Sleeper
(Post 18929395)
back ttt |
Built 1998 Trans Am LQ9 Stroker 408 Price? |
$18500 |
Do you have any idle r walk around video of car |
Originally Posted by O.V.P.
(Post 18948369)
videos
(Post 18948369)
Do you have any idle r walk around video of car http://vid595.photobucket.com/albums...pstiiastgl.mp4 http://i595.photobucket.com/albums/t...pstiiastgl.mp4 start idle rev http://vid595.photobucket.com/albums...psbkdvznow.mp4 http://i595.photobucket.com/albums/t...psbkdvznow.mp4 click the link and it opens in a new window Im not sure how to make them bigger. |
8 Attachment(s) |
Up top |
Sorry if I missed it in the description, do you have a dyno or a guess number on the horsepower? |
Originally Posted by Aliens05
(Post 18964904)
© 2024 MH Sub I, LLC dba Internet Brands
