1996 RCSB s10 LSX swapped roller
Year: 1996
Make: Chevrolet
Model: S-10
Price: $2000
Mileage: 196000
Private or Dealer Listing: Private Listing
Location (State): AR
Color: Red
LS Engine?: Car has LS engine
Asking $2000 for the complete roller
1996 rcsb s10, notched/boxed frame for AC, relocated Fbody fuel tank (was 4.3/NV3500)
Ford Explorer 8.8, 3.73 gears and disk brakes (drilled for GM bolt pattern)
BRP 1 3/4" in frame LT headers, coated
BRP transmission mount
CPW plug and play swap harness
CPW poly engine mounts
Jegs aluminum radiator
Dodge Interpid dual fans
Aluminum remote PS reservoir
Homemade Cal-Trak bars
Racetronix fuel pump with hotwire kit
16" Camaro wheels with brand new Falken tires
Had a fiberglass roll pan that I never installed
It has a small dent in the driver side fender by the headlight
One of the wheel studs on the passenger side broke loose while I was changing wheels/tires
It needs a new windshield
Need to figure out where you want the fuel fill
The drain plug on the radiator stripped (easily fixable)
Bump. I have an ls1 with a Vic Jr/4150 tb, 243 heads, brand new ms3/PRC .650 springs, trunion upgrade rockers, 42lb injectors, ls7 lifters, melling oil pump with around 12k miles on a rebuild and no miles on the cam/springs that I'll take $2500 for. I have a 4l60 built to perform a built lvl2 specs with a brand new yank ss4000 and a deep pan I'll take $1000 for.
