1979 ford fairmont futura l33 s480 turbo
Year: 1979
Make: Ford
Model: Fairlane
Price: $11000
Mileage: 1234
Private or Dealer Listing: Private Listing
Location (State): AZ
Color: Beige
Transmission: Automatic
LS Engine?: Car has LS engine
11k or trade
Car runs consistent low 9s . Best Et 9.2 Best Mph 150
Car is a great sleeper.
Dont reply if your not seriously wanting to trade.
Clean Title . Car needs nothing currently. Track Ready. Might go out this weekend and try to squeeze into the 8s
-all lights work/ windshield wipers/horn ect
-10pt s&w mild steel cage with swing out / Cage is certed
-AJE k-member / lower control arms
-AJE engine mounts
-Strange front struts/coilovers 12-175 from team z
-camber/caster plates
-sn95 front brakes/spindles
-kirkey alum seat
-new g-force 5pt harness
-window net/mounted
-bogart wheels 15x10 single beadlock rear hoosier 28x10.5 et drags
-15x4.5 front with new tires
-Team z double adjustable upper and lower rear arms
-Team z Spherical (solid) Bushings
-sub frame connectors
-10gal fuel cell
-magnafuel 4303 pump
-Gold Box Ecu
-8 feed and return aqp fuel line
-8.8 rear end 31 spline axles 3.55 gears 1350 u joints new drive shaft
-team z anti roll bar
-l33 shortblock
-799 heads
-btr springs
-ls7 lifters
-mellings oil pump
-sfi crank pulley
-fbody pan
-ljms stg 2 turbo cam
-ebay headstuds
-fic 1000 injectors
-s480 t4 92 wheel Billet
-2.25 to turbo/ fipped truck manis
-FTI built th400 (sfi bell)
-tci flex plate
-trans brake
-Good ptc converter
-hurst shifter
-tuned on e54
Sure im forgetting some stuff.
