2007 Twin Turbo LS7 C6 1100whp
Year: 2007
Make: Chevrolet
Model: Corvette
Price: $49000
Mileage: 22000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Black
LS Engine?: Car has LS engine
2007 C6 Fully Built Twin Turbo with 22k miles, 1100whp on e85 and 800whp at 10lbs on 93. The drivetrain is fresh with less than 5k miles.
ENGINE
ERL LS7 block with recent refresh. Cylinders were cleaned up and has new wiseco 4.135 pistons and compression was set to 10.5:1, Callies ultra H-Beam Rods, dragonslayer crank, All bearings were replaced as well as a new kateck oil pump. WCCH ported ls7 heads and stock ls7 intake manifold, Pfadt engine mounts. Turbo kit was built by ips motorsports, Low mount twin Forced Performance gt3586r HTA billet wheels. Turbos were also serviced and inspected by forced performance ago during the refresh. Flex fuel sensor. Katech Valve covers and coil brackets. ATI damper. Katech Belt tensioner. Mezier WP419 Billet mechanical water pump, Dewitts radiator, D3 dual spal fans. Full dual 3 inch exhaust with center exit for Breathless performance diffuser. Mechman 220amp billet alternator.
FUEL SYSTEM
Fore Triple Walbro 450 fuel pump setup with controller, -10 feed line and -6 return all AN fittings, Aeromotive Regulator, ID1700 injectors
DRIVETRAIN
New Mantic triple clutch, Driveshaft Shop 3.5 inch aluminum driveshaft, RPM z06 level 6 Tr6060 and stage 3 z06 diff, Pfadt trans mounts, line lock, half shaft safety loops. New Z06 front brakes and base brakes to fit 15 inch rear wheels.
SUSPENSION
Pfadt coilovers, Delrin suspension bushings, LG drag spindles, Weld RTS 15” with 315 ET Streets, Weld RTS 18x8 fronts with Toyo 255 tires.
INTERIOR
Caravaggio race seats, Caravaggio center console lid, Caravaggio E-brake lever and boot, Defi boost and fuel pressure gauge, Ethanol gauge, Boost leash Boost controller with on board Viair air system, NGK AFX wideband, Fire extinguisher, Touch screen double din stereo, focal 3 ways and JL amp.
Exterior
MCM carbon fiber hood, C7 ZR1 front carbon splitter, Extended carbon rear spoiler, Carbon Zr1 Side skirts and Breathless performance rear diffuser.
2007 C6 Fully Built Twin Turbo with 22k miles, 1100whp on e85 and 800whp at 10lbs on 93, Tuned by James Karger. The drivetrain is fresh with less than 5k miles.
ENGINE
FUEL SYSTEM
DRIVETRAIN
New Mantic triple clutch, Driveshaft Shop 3.5 inch aluminum driveshaft, RPM z06 level 6 Tr6060 and stage 3 z06 diff, Pfadt trans mounts, MGW shifter with billet shifter box, line lock, half shaft safety loops. New Z06 front brakes and base brakes to fit 15 inch rear wheels.
SUSPENSION
INTERIOR
Exterior
The forgelines are no longer with the car but here are the pictures of it on the forgelines.
Asking $49k
Looks like my old C6. What a fun car. It has such low mile because it sat in a garage and never saw rain. Looks like it still has the Katech aero kit still on it too. Nice to see the refresh.
GL with the sale.
GL with the sale.
