98 Trans AM over $30k in mods
Year: 1998
Make: Pontiac
Model: Trans Am
Price: $20000
Mileage: 130000
Private or Dealer Listing: Private Listing
Location (State): CA
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Over the years I have put over $30k of tasteful mods in her to create the ultimate, badass, reliable street car. I have done everything including engine, transmission, suspension, interior, and a few other Ls1tech mods. I have receipts, dates, and miles for 99% of the parts installed. Everything was done by myself with the exception of the engine internals and tune. Tuned by Excelsior Motorsports in California. Mainline dyno put down 400rwhp (very stingy dyno), but I didnt build a dyno queen.
Wheels/Brakes
UMI C5 brake upgrade kit (calipers were customized to have the corvette etching removed and were High temp painted Blue and cleared with White Trans Am lettering.
C5 slotted rotors with Akebono High performance brake pads (no squeal)
Steel braided lines
Strano Master Cylinder Brace
Chrome Firehawk Rims (not replicas)
Bridgestone potenzas up front and Nitto Nt555 G2s on the rear. Both 275/40/17 with about 75% tread left.
Suspension
Sphon Tunnel Brace
UMI Non adjustable torque arm
UMI Bolt in Subframe Connectors
UMI Poly/Roto rear LCAs
UMI On car double adjustable Poly/Roto panhard bar
UMI Torque arm relocation Crossmember
New AC delco rubber transmission mount
Moog greaseable upper and lower ball joints
Moog inner and outer Tie rod ends
UMI Front and rear solid sway bars with poly bushings and new end links
Bilstein shocks all around
Transmission
Performabuilt Level 2 Transmission with transmission cooler (4L60E)
FTI Billet 3600 converter
TCI SF rated flex plate
Fuel
Racetronix fuel pump
Fast 36lb fuel injectors
Custom Billet Motorsports Chrome fuel rails
-6 braided hose and fittings throughout
Engine
Trickflow 220 Heads BTR
New GM rockers with BTR trunnion upgrade
BTR dual platinum valve springs with titanium retainers
GM MLS gaskets
Johnson 2116LSR lifters
ARP crank pulley bolt, and any other bolts used during the install
Titan IV cam
Pushrods
Valve cover ls6 conversion
Ported Melling oil pump 10295
Ls2 water pump
ATI UD pulley
LS2 timing chain set with trickflow damper adapter
FAST 102 intake
Nick Williams 102 Throttle body
New Knock sensors and harness
Exhaust
TSP 1 7/8 catted headers with stage 8 locking header bolts
Magnaflow quad tipped cat back
Electric cutout with switch
Interior
New black carpet
New wrapped black headliner
Interior painted black
Miata AC vents with Stainless bezels
New touch screen head unit with Bluetooth
CDT speakers from Kee audio
Custom Black Napa leather with silver stitching leather from Redline goods steering wheel, shift ****
Dash bezel
Door inserts
6le leather seats with brackets and rear seat covers
Custom gauge cluster overlay
Shift indicator overlay
LED lights replaced dull yellow bulbs
Miscellaneous/Other
10 bolt rear end, rebuilt with new 3.42 gears and new Auburn race posi
Aluminum rear diff cover
Raptor hood with functioning air box
HID fog lights
New headlight motors with Metal gears installed
Im sure ill think of more later on
She has been on AMSOIL 10w30 since I bought her. Engine and transmission have only been one for around 2000 miles. A few bad things, really only the driver side window needs help getting up sometimes. Paint looks perfect from more than 8 feet away but there are a few chips here and there its 20 years old for Gods sake. Always garaged while at home. No accidents. LMK what you guys think. 20K OBO. Pics to come
