FS: 800 HP LSA Swapped '08 TBSS (3SS)
Year: 2008
Make: Chevrolet
Model: TrailBlazer
Price: $25000
Mileage: 113000
Private or Dealer Listing: Private Listing
Location (State): CA
Color: Black
Transmission: Automatic
Drivetrain: 4WD & AWD
The entire powertrain has been replaced using a brand-new Chevrolet Performance LSA supercharged crate engine and Performabuilt Level 3 Invincible series 4L70E with 2.84 First/1.55 Second gear and Sonnax billet upgrades. The blower has been ported by Weapon X (manifold and snout), it uses a Concept One 8-rib billet accessory drive to spin a Griptec underdrive supercharger pulley from ZPE. Kooks 1 ⅞-inch long-tube headers and Green cats feed into the stock catback exhaust. It has a healthy idle but is quiet on the highway. The cold air intake is custom made, which mates to a Weapon X ported 90mm LS3 throttle body. SPAL electric fans (from PCM of NC) and a Fluidyne heat exchanger keep things cool. The factory E67 ECM has been converted to Flex Fuel with a GM sensor by Kraftworks, who did the majority of the work. DeatschWerks injectors and a Lingenfelter pump supply the gasoline or E85 mixture. The front and rear driveshaft U-joints have been upgraded, but the rearend is stock. It also has an FTI triple-disc billet converter and PCM of NC trans cooler (in brake duct). The truck rides on Michelin tires with the stock wheels, but has upgraded Baer rotors and pads.
On the engine dyno, this combo made 825hp and over 600-rwhp once installed. It has since been de-tuned in order to run A/C using the Concept One kit. I have the factory accessory drive with an ATI overdrive pulley if needed (for kill mode). The entire installation was covered in Truckin magazine, however, some of the other work such as modifying the crate engine and building the trans were covered in VETTE, Chevy High Performance and LSX Magazine.
I absolutely love this truck, however, it is time to move on for me. I have a new project in the works and needed to purchase a new tow rig/daily. More info is available, however, feel free to check out the links below.
Start-Up, Idle and Walk Around Video
Flex Fuel
http://www.trucktrend.com/how-to/eng...or-more-power/
4L70E Transmission Build
http://www.superchevy.com/how-to/tra...r-gear-ratios/
LSA Bolt-On Dyno Test
http://www.superchevy.com/how-to/eng...y-last-725-hp/
LSA Cam & Final Dyno
Concept One Front Drive Kit
http://www.lsxmag.com/tech-stories/p...kit-lsa-swaps/
Pics Below:
https://inlandempire.craigslist.org/...526777472.html
Yes.
About 4,000. It drives nice around town, though.
High 500s at the tires? It is down about 3psi. It has a 2.55 upper but the stock size lower. With the factory LSA accessory drive it had the same upper but the overdrive lower.
For full price I will throw in some extra parts: GM LSA accessory drive with ATI overdrive balancer, front driveshaft, Spicer U-joints, and the stock 4L70E. I also have the stock air intake with K&N filter, fog lights, etc that I will throw in regardless.
I'm really curious about the daily driveability of this. I have a few buddies with similar LSA builds in the CTSV platform, so from a motor standpoint I'm not really concerned and you've built a gnarly transmission. Any rear end or transfer case whine? Are the shifts heavy, as a built transmission typically does, or is it still fairly smooth? This is an awesome build.
The Baer brake rotors/pads story is now live (http://www.lsxmag.com/tech-stories/b...r-rotors-pads/).
Also, I'm not sure why that link broke on the Concept One story (http://www.lsxmag.com/tech-stories/p...kit-lsa-swaps/).
