WTB 98-02 T/A/Formula under $10k AUTO looking for a 98-02 transam or formula cam car or ls2/ls6 swapped must be an Automatic mileage isnt an issue dont want any body damage clean title is favorable may be interested in full bolt on ls1's as well anywhere in the mid atlantic.. NY down to VA thanks |
bump.. no swapped cars? |
For Sale: 1998 Pontiac Firebird Trans Am LS1 5.7 V8 Auotmatic 4L60E Transmission Black Exterior Dark Grey Interior T-Tops Power Windows Power Door Locks Tinted Windows (5% Rear Hatch Window/ 5% T-Tops/ 35% Side Windows) AM/FM CD Player Clean Title 90,000 Miles on the chassis 33,000 Miles on the Engine/Transmission 2,500 Miles on all the Non-Stock Performance Add-Ons Engine: New F.A.S.T 102mm Intake Manifold $1050.00 . New P.T.M. 102mm Throttle Body $325.00 . New Patroit Performance Stage 2.5 LS6 "243" Ported and Polished Heads w/Dual Valve Springs up .650 lift $1,300.00 . MTI S1 Camshaft 244int Dur/244ext Dur, .612Int lift/.612ext lift, 112 LSA $250.00 . New Trickflow Chromoly Pushrods $120.00 . New GM Head Gaskets $75.00 . New Oil Pressure Sending Unit $75.00 . New Crank Sensor $35.00 . Pacesetter Long Tube Headers $250.00 . New Powerbond Underdrive Pulley $225.00 . New LS2 Fuel Rail Kit $250.00 . FMS 42lbs Injectors $225.00 . New SLP Air Lid Kit $100.00 . New NGK TR-55 Spark Plugs $35.00 . Oil Changed with Royal Purple and has Mobil 1 Oil Filter . New Granatelli Motor Sports 255 lph Fuel Pump $130.00 . New AC Delco Fuel Filter $6.00 . MagnaFlow Muffler straight Pipe with a Manual Cut-Out if needed to a ORY-Pipe $300.00 Transmission: New Fully Rebuilt 4L60E with Shift Kit Under 100miles $1,300.00 . New Yank SS4000 Torque Converter $830.00 . New B&M Transmission Cooler $100.00 . Drivetrain/Suspension/Wheels and Tires: New UMI Adjustable Torque Arm Tunnel Mounted with Safety Loop $415.00 . New BMR Non-Adjustable Lower Control Arms $120.00 . New Competiton Engineering 3 Way Drag Shocks $95.00 . New Motive Race Competition 3.73 Ring and Pinion with all new bearings $350.00 . Tuning: Tuned at All Out Performance in Fresno CA. $700.00 . Did a 2002 PCM Swap ($75.00 for the PCM) with all wiring done so a wider tuning table could be done and is great for a Nitrous build and makes things alot easier. . The Trans Am Dyno Numbers are with a Speed Density Tune and the numbers are unlocked, so if locked would be easy 50-75rwhp more on the dyno graph, but i'm not a dyno queen and looked to make the car drive and perform great. . 427rwhp/371rwtq on a unlocked torque converter pull!!!!! THATS GREAT NUMBERS ON UNLOCKED and on a N/A Setup!!!!! . I have all receipts to all the purchases made in the last 3-4 months on all the parts listed. Most which were purchased from Summit Racing or Texas Speed Performance. . Car is in good shape just has a 1 1/2 inch crack in the fiberglass on the passenger side front fender. . I have ALL the A/C equipment to be put back on if needed, i just took off for weight reduction. . Car Has Gone 11.6 with a 1.6 60ft 115mph at Sacramento Raceway on 10-20-2010 Will be easy 11.0-11.2's with new setup and with a 4.10-4.30 gear swap high 10's. . . . Asking Price is $11,500 o.b.o was asking $12.5k "PM" me with offers No test drives unless money is shown up front and don't low ball with any dumb offers not in a hurry to sell!!!! . Possible Trades: . 01-02 Camaro SS 6spd . 64-72 Nova . 67-69 Camaro . 70-73 Camaro . 86-87 Grand National . 70-73 Firebird . 70-75 Chevrolet Silverado 4x4 Lifted (Automatic Only) . 65-73 El Camino . 94-96 Toyota Supra . 64-71 Chevelle . 94-96 Ford F-250 or F-350 Powerstroke 4x4 (Automatic Only) and if trade is less value then mine expect to put cash on top of trade. http://i296.photobucket.com/albums/m...T/CIMG1441.jpg http://i296.photobucket.com/albums/m...CIMG1442-1.jpg http://i296.photobucket.com/albums/m...T/CIMG1446.jpg http://i296.photobucket.com/albums/m...T/CIMG1434.jpg http://i296.photobucket.com/albums/m...T/CIMG1435.jpg http://i296.photobucket.com/albums/m...s/IMG_9571.jpg http://i296.photobucket.com/albums/m...edynosheet.jpg Dyno Tuning Video 8-25-2010: http://www.youtube.com/watch?v=6rnRkOivZyE 11.6 run with a 300lb driver and on a wednesday night drag night with sorry track prep and on the street exhaust setup and street suspension setup. 10-20-2010 http://www.youtube.com/watch?v=0HstdTjYWiQ |
01 ta ws6 |
99 formula, Bone stock except for flowmaster exhaust, A4 with 66K miles... replaced oil pan with new one with gasket and also replaced dash due to sun cracked.. Paint has some issues (had it painted Copper metallic w/ satin black on roof, and painter got runs and dust in the paint)... Asking $6000 as is, or $7500 with a new paint job... PM me if your itnerested at all... |
have you looked on cars.com for our area? |
Bump it up If anyone knows of an ls2 TA or formula that is exactly what I want |
Take a look at this car. Not too far from you. Im flexible on the price, need to sell bc im moving. car is unbelievability clean https://ls1tech.com/forums/vehicle-c...l#post14241783 |
I have a swapped Monte Carlo SS, if you want more details let me know through PM. |
© 2024 MH Sub I, LLC dba Internet Brands
