clutch pedal stuck!!!!!!!!!
Wat up!!! So was reversing the car out the driveway and suddenly it shut off as if i had poped the clutch out but i didnt........the reverse was stuck and the clutch pedal got really really hard....i was able to pop it out of gear but the clutch staied hard, any ideas or suggestions??????
Simalar thing happened to me. I went to shift from 1-2 and the clutch popped to the floor and I couldn't get it to come back out and the car died. I got it to pop back out but it wouldn't go back in. Turned out to be a busted throwout bearing.
If you need any help, let me know, I've replaced everything transmission related on LTx cars.
I'm trying to find the write-up that I used a long time ago.
This one will help for now, it's for a LS1 T56, but a lot of the steps are similar.
http://www.installuniversity.com/ins...ch_install.htm
I'll try to find one for a LT1 T56.
The t/o bearing is pinned to the pressure plate. It that is the culprit, you should be able to get a new one and replace it without having to replace the clutch. You'll know if its your t/o bearing once you drop your tranny.
appreciate it!
