Guys, I need help/advice... Tuning/spark? problem...
My thread is here: (in the PCM diagnostics section)
https://ls1tech.com/forums/pcm-diagn...ues-spark.html
Not to sure but i had a similar problem with my car when i first got it. i know you said you changed the spark plugs, that was my problem. try using just normal ac delco ones and double check the gap. i havent done plugs in a while, but im not sure if that sounds right. thats what fixed my problem. good luck man!
