Western Members CA, AZ, NV, UT, CO, NM, HI
Possible rear end donor cars?
Old 06-05-2009, 01:53 PM
ss.slp.ls1's Avatar
Default Possible rear end donor cars?
What are all the possible '93-'02 cars (with option codes that I should be looking for) that I could find a suitable replacement 3.42 geared rear end for a '97 V8 M6 non-TC car?
I know some V6's came with 3.42's but I don't know what year or option codes to look for?
I know all the V8 M6 cars came with 3.42's.
I don't know what channel rear I have to look for and I don't know how to tell a 3 channel from a 4 channel by just looking at them...
Old 06-05-2009, 02:19 PM
MrElectric03's Avatar
I take it your car hooked pretty good at Irwindale last night?
Old 06-05-2009, 02:24 PM
FearTheDeer's Avatar
I know S10's have the same rear, and I think the V6's have 3.73's in them. But not sure if its what ur looking for.
Old 06-05-2009, 02:31 PM
383lt1impala's Avatar
He can use the gears from an s10. But the rear wouldn't work I don't think s10s have a latter bar style suspension.
Old 06-05-2009, 03:18 PM
LS1Adam84's Avatar
3 Channel will have the hole in the center of the diff for the speed sensor, 4 channels has them on the axle housing.
If you are non tc car then you would be a 3 channel rear car, and like I said man just look for one hole on each axle and you know then that it is the wrong rear.
You see a rear with the hole in the diff as your looking at it, if my brain hasn't crapped out on me last time I had to swap my rear, it will be center of the diff on the front side, or the opposite of the diff cover side up top.
I will most likely be looking at some point too but I will be going for a 12 bolt (I know i can get a 9 in. but I want to keep GM parts on this one). I hope this helps ya a little.
Old 06-05-2009, 03:29 PM
ss.slp.ls1's Avatar
Broke it the day before...
Didn't know that.
Hmmm, I wonder if you can convert it somehow?
Thanks.
Old 06-05-2009, 03:43 PM
I meant torque arm style suspension. And I wouldn't most likly its differant widths and its still gonna be weak.
Old 06-05-2009, 03:47 PM
ss.slp.ls1's Avatar
I wish Bbody cars used TA's...supposedly their diff's are strong.
Old 06-05-2009, 04:01 PM
LS1Adam84's Avatar
No problem man.
Old 06-05-2009, 05:19 PM
hlaalu's Avatar
no 9" ?
Old 06-05-2009, 05:21 PM
Got that right there's mutiple 4300+lbs bbodies in the 9s with the 8.5!!!!
Old 06-05-2009, 05:26 PM
Revelation Z28's Avatar
the GN used a torque arm on their 8.5, i dont know if its all of them though.
Old 06-05-2009, 05:34 PM
Ohh yea. The gnx the normal gn didn't they had a trianglelated 4link like the bbodies.
Old 06-05-2009, 06:03 PM
ss.slp.ls1's Avatar
I wonder if anyone has either converted the Bbody rear end to be used on a Fbody or if anyone has fabbed up the Bbody 4-link and rear end onto a Fbody???
Old 06-05-2009, 06:16 PM
Hmmm idk. But I think in the newest gmhtp mag. Or idk remember where. But there's quite a bit of grand nationals in the 8s running the stock gears/posi and axles. Like on mine I'm going with mosers 33 spline axle and spool package.
Old 06-05-2009, 06:59 PM
MSS91Z28's Avatar
S10's have a narrower rear end, about 4" narrower I believe..wouldnt work unless you got some deep dish wheels or wheels with less backspacing.
And don't forget you'd have to convert your brakes over on to the new rear as well.
Old 06-08-2009, 01:14 AM
lowerthanyou00's Avatar
[QUOTE=ss.slp.ls1;11709435
I don't know what channel rear I have to look for and I don't know how to tell a 3 channel from a 4 channel by just looking at them...[/QUOTE]
srj let me down
naw but if your looking for a complete rear end theres always seems to be half a dozen 93-97 f bods and like 1 98+ f bods at the pick a part up the street from me
if u need a 4 channel u can always just swap axles and switch backing plates from ur old one
Old 06-08-2009, 03:52 PM
ZexGX's Avatar
RPO code GU6 means 3.42 ratio
RPO code G80 means positraction
V6's didn't come with TCS/ASR until sometime around '00
Old 06-08-2009, 04:00 PM
LS1Adam84's Avatar
If you drive a V6 and need tcs/asr then damn you got issues. Just sayin.
Old 06-08-2009, 04:12 PM
ZexGX's Avatar
Doesn't matter if it's a V6 or a V8 when it rains. Just sayin.
Quick Reply: Possible rear end donor cars?
