Western Members CA, AZ, NV, UT, CO, NM, HI
Please help...tranny won't shift...
Old Sep 10, 2009 | 02:02 PM
DobsZ28's Avatar
Default Please help...tranny won't shift...
So lately I've been noticing that when I shift from fourth to fifth, there's a grinding feeling...didn't think much of it until today, when I was trying to shift from fourth to neeutral, and the shifter was just stuck. I stopped the car, tried to get it to first, second, nothing; the shifter is stuck, and if I try and shift all I feel is grinding coming from the shifter.
Car just hit 50K, had the tranny serviced, oil changed, everything...
So basically, is my tranny done for?
Old Sep 10, 2009 | 02:20 PM
180ls1's Avatar
the only thing i can suggest is to give it a rev while trying to put it into gear that might help to get it to limp to a shop. Other then that it sounds like it needs to be torn apart.
Old Sep 10, 2009 | 02:24 PM
DobsZ28's Avatar
fuucck...do you know any good shops in san diego? i've been taking it to Miramar Automotive for most of the basic stuff, but I figure they'll try to rape me on a transmission rebuild.
Old Sep 10, 2009 | 11:54 PM
SSMOKIN_Y2KSS's Avatar
cms in elsinore is probably ur best bet...its time for a rebuild sounds like clutching teeth and syncros
Old Sep 11, 2009 | 12:10 AM
180ls1's Avatar
i saw that eddielb has his t56 go out also. talk to him and see what he came up with. But if you can rent a car dolly and have something to tow your car with i think CMS would be your best bet.
Old Sep 11, 2009 | 05:57 AM
DobsZ28's Avatar
^^^ any idea of how much CMS will charge?
Old Sep 11, 2009 | 01:22 PM
180ls1's Avatar
have no idea, it might be something inexpensive to fix. you can send it off to finishline transmissions, they are a sponsor here they have a couple of options. http://www.finishlinetrans.com/transmissions/index.htm
Old Sep 11, 2009 | 02:39 PM
DobsZ28's Avatar
^^^ thanks for all your help. dropped it off at the shop that did my most recent service, so we'll find out what happens sometime today hopefully..
