People with t56s... do your transmissions get hot after about 30 mins of driving? and i mean hot to the point you can feel the heat through the shift knob? if not, what fluid are you guys running? |
yep not hott hott but you can feel the heat from it |
After about 3hrs of straight driving mine will start to get warm. Stock fluids. |
im askin cuz i just switched to valvoline atf dex3 from chevron dex3 and i swear my trans has been getting hotter with the valvoline. guess its time to switch back |
I feel the heat from mine, but i was told it aint no biggie. It will suit me good in the wnter time, lol |
yeah, im used to a little heat, but i just noticed today driving to work that my shift knob was HOT. lol |
Heated shift knob will be perfect for this winter! |
I have two cars with T56 transmissions. One that I've put over 100k miles on myself. I have never noticed any heat from either. I use Valvoline MaxLife dex/merc in both cars. |
hmmm. fawk. what causes the tranny to heat up, its brand new fluid and it was filled with 4 quarts |
Originally Posted by 1Loudz28
(Post 12241500)
Originally Posted by ss.slp.ls1
(Post 12241503)
Maybe your vent tube is clogged...(shot in the dark) |
(Post 12241543)
wheres that located on the trans and how can i check it? The black hose on top. |
thanks!...any trick to checking it? |
(Post 12241567)
(Post 12241577)
Pull it off and blow through it, lol. |
(Post 12241577)
Havent noticed it through the shift knob...ofcourse it gets hot though. I run Royal Purple in mine. |
I'm driving mine without the shift boot because I broke it when I installed the new shifter. It gets hot for sure, but nothing unbearable. I'm using whatever ATF fluid recommended from the factory that I put in around 10k miles ago. |
i dont get heat from my shift knob but of coarse i do from the shift stick which is normal with aftermarket shifts and stick, btw the fluid is not really a big deal and i highly doubt it caused any heat increase the only time ive seen fluid choice resulting with problems is when running synthetic or royal purple(worst thing for a t56) myself i preference two quarts of dex/mer and then two quarts of type f |
I'm an auto guy but I always thought the syncromesh was better for these trannys. |
© 2024 MH Sub I, LLC dba Internet Brands
