Any legal cats in California?
You could always purchase those direct fit cats through Summit and have then shipped to someone OUT of California. That person could then ship them to you......just a thought.....
I think I'll prob order the magnaflow direct fit cats to a friend in nevada and have him ship them to me. I'd put the fake cats on if it weren't for the mobile smog dyno's near me. The scheduled smog check isn't hard to get around, it's the random mobile ones that will get me.
RedNeck Z,
Since you had what I currently have now, what was the difference between the JBA shorties and direct fit high flow cats vs your current setup? People keep saying to remove the shorties and put on long tubes, but there is a COST and Emissions issue involved, so its sort of counter productive in that respect for me.
Thanks.
Thanks.
RedNeck Z,
Thanks.
Thanks.
Redneck Z......
Are you running the LS1 cammed or the LS6 achieving your current power? I ask this because I am running a crate LS6 with the JBA shorties, Magnaflow high flow direct fit cats out the back through a Flowmaster 80 series. I also have SLP CAI which sucks from the bottom below the radiator, thus the reason for the new crate LS6 engine. The previous owner was driving home in the rain. He hit just enough water resulting in a splash up into that SLP intake. The result was a rod out the side of the block. I am wondering how much my car is putting down to the ground with this otherwise stock setup. It does also have a tune on top of the install. It runs amazing, but then again, its my first LSX series engine.
Which muffler would you recommend that I go with as far as replacement? I was thinking maybe just remove the Flowmaster and hang a Magnaflow in the exact same position and minimize the pain and cost. Any other thoughts would be appreciated.........
Thanks,
#32
As an update to the original topic of this thread, I called Magnaflow. None of their OBDII cats are legal for 98-02 LS1's in CA. They also have no plans of ever making one because CARB has decided that this car can only have cats from the dealer installed..period. Looks like good old CA has completely done away with any options for cats other than OEM. I can't believe CARB has so much control now! I expect in the near future that CARB will once again talk about making a law where only dealers and CARB certified shops can work on your car and only use CARB certified junk. CARB wants it to be illegal for you to work on your own car. I just bought my car back after 3 years without it, and had forgotten how crazy and power hungry we are allowing CARB to become..UGh!
393, aftermarket, buy, california, cat, cats, checkpoint, hemi, legal, magnaflow, mobile, random, replacement, shops, smog, wont, work
