HELP!!! car doesnt go into gear
just put in a new pilot bearing nd had the flywheel resurfaced.
bolted everything up (not first time i do clutch swap btw)
bled slave for an hour
car wont go into any gear while on... i started car in 1st and car wouldnt get out of gear.
slave has ~10k in in it, original master with drill mod
car goes into gear fine when off
LS7 clutch ls2 flywheel btw
02 t/a ws6
02 t/a ws6
i had the EXACT problem when i slapped a spec stage 3 in my bros car last month. long story short i accidentally mixed up two of the pressure plate bolts with other bolts and they had larger shoulders on them then they were supposed to have. the larger shoulders of the wrong bolts were actually making contact with the disk when fully assembled and consequently not allowing disengagement.i had to retrace my steps completely to find this out.
