Western Members CA, AZ, NV, UT, CO, NM, HI
need smog help
Old 03-07-2012, 06:33 PM
Thizizkai's Avatar
Default need smog help
Hey guys need help with figuring out what I need to pass smog...car is a 95 Trans am lt1 k&n intake,bbk shorties are the only mods besides muffler delete....here are the test results
Old 03-07-2012, 07:19 PM
roughneck427's Avatar
Your O2 level should be around 1% and its 3.9% you have high NOX which is high cyl temp id say looks like a lean miss fire. The HC are high due to the misfire put a scanner on it and see what the LTFT or block learn are and post em up.
Old 03-07-2012, 07:23 PM
Thizizkai's Avatar
Alright cool thanks I'll have to check in the morning after work....there are no check engine light that would indicate anything so I'll get a scanner from AutoZone and see if that shows anything....
Old 03-07-2012, 07:46 PM
Well 95 is a goofy year obd1 with an obd2 connector unless you have an open or short to ground on a sensor its had to set a ses light. Your best bet is to get someone with a scanner besides autozone and look at fuel trims maybe clean your MAF as well
Old 03-07-2012, 07:57 PM
Thizizkai's Avatar
Wtf...that sucks...ok I'll get the maf cleaned during lunch.and try to see if I can find a compatible scanner
Old 03-07-2012, 08:56 PM
allblacksrt4's Avatar
go to mexico smog place and stick $100 bill in each tailpipe
Old 03-07-2012, 09:15 PM
Vette310's Avatar
^^^^ wont happen, the shop wont take the risk because it failed already... he needs to fix the problem.
Old 03-07-2012, 10:18 PM
Make sure the 90 degree boot on TB is on correctly and no rips in it. Also look for any obvious vacuum leaks.
Old 03-07-2012, 11:14 PM
Thizizkai's Avatar
Ok I did a quick cleaning of the maf and check the elbow...no rips everything seems fine....still gotta find a scanner to see if anything shows up...I did notice extra heat on the driver side i'm assuming from the headers....seems hotter than normal tho...
Old 03-08-2012, 03:58 PM
Thizizkai's Avatar
Where can I get a scanner that is compatible? Auto zone had obd1 and obd2 but the port plug for obd1 wouldn't work and the obd2 couldn't read
Old 03-09-2012, 09:05 PM
Thizizkai's Avatar
anyone? all I need is the scanner...doing plugs and wires this weekend ..
Old 04-12-2012, 01:52 PM
Thizizkai's Avatar
Been doing some tune work....did plugs and wires...cleaned filter checked timing oil change Trans flushed and still noticed a miss...anything? I used single platinum AC Delco spark plugs...pretty sure I should use double...but it was laying around..I just threw them on...
Old 04-12-2012, 02:01 PM
1ltcap's Avatar
low co2 too.......either cats removed, or dead. also, depending on the type of cat, the high nox could be a cat problem too.....but most likely an egr problem.
Quick Reply: need smog help
