QUESTION::: T56 Sensors? pls help
So i keep on getting a P0500 code, I replaced the sensor located on the left side of the transmission (drivers side) next to the reverse solenoid. Does anyone know how many sensors the t56 actually has? Does the engine carry a speed sensor too? Thanks for the help in advance.
You might need to replace the speed sensors at the axles, they are behind the rear brakes and are magnetic sensors, you can find them by looking behind the rear brakes and see the thing that looks like a gear and there should be a sensor attached to the axle tube with the tip pointing towards the gear.
If you need help, I can get a picture for ya when I get home and send it to you, if these go out there is a possibility that it will throw that code as well.
