Need help/suggestions with my lt4
i have a 97 camaro with a an original lt1 block but has lt4 heads, throttle body, and injectors...tranny is just a ws6 rebuild, the motor is balanced and blue printed, bored 30over, it has an lt4 cam/lt4 kit, ported and polished cast heads.... the camaro is throwing a few codes and i beleive they are all related to one issue. the codes are (P0420 catalyst system efficiency below threshold-Bank 1) (P0336 cranksfat position sensor A circuit range/performance) (P0335 Crankshaft position sensor A circuit) (P1371 ICM 4x reference too few pulses). the car fires RIGHT up and drives fine but i feel a lack of power. this camaro dynoed @400HP (SUPPOSEDLY)and i dont feel 400HP at all. fropm researching online im thinking its the opti and thats whay a shop said when i called them as well
Why are you starting another thread when you already have one going in the lt1 section with the same questions?
https://ls1tech.com/forums/lt1-lt4-m...ns-my-lt4.html
We're trying to help you there, you just did not give us enough info in the first post.
I was told to post it in the west section...hints here I am
