question about weld drag lites for front
will a weld drag lite rim that is 15 x3.5 with 1.75 back space work for the front of my 98 ls1 camaro? will i have to run spacer and longer wheel studs????
that should be fine on the street. NHRA rules say if it is an 1/2" stud then it needs to come out of the nut 1/2". Another other words whatever the diameter of the studs is, needs to come out of the nut by the same or more. Some tracks dont enfoce it though.
http://www.summitracing.com/parts/sum-7540121/overview/
Those are fine, I use to run those. Somethimes I would have issues at the track with tech guys. They hold fine, I replaced to longer studs for them not to question at all. you can leave your OEM style wheels on for tech, then replace them after you pass tech, (what i did)
