View Poll Results: Where would you go?
strictly performance van nuys
13
34.21%
haddad motorsports inglewood
25
65.79%
Voters: 38. You may not vote on this poll
Haddad or Strictly for turbo build?
#163
Originally Posted by 52172
I do know Rob charges 1500 to tune a FI car and Haddad charges 500 big difference there, but I will not make my decision on that alone.
#164
Rob did you get the email inquiring about using a new ls2 block vs preping my ls1 block and how it would effect the cost? Mike wants to use an iron 408 for the bottom and I think that would create way too much backpressure with my turbonetics TC-76MPS wheel turbo? The turbo is only a T-4 housing.I like the idea of using a 366CI bottom end with my stock crank and ls2 block. He said he could finish the job for 8k with a 408? Do you think we could get the job done within my budget with a new ls2 block? How much would I be spending to prep my ls1 block for the forged bottom end? An ls2 block is 850 new I think or maybe 900? thanks Rob.
#167
what kind of work have you had done there?
#170
Why dont you stop posting up here, choose a shop, then get the work done and report back. Stop dragging everyone into a fight, between shops people are gonna have good and bad experiences. You seem like your stiring the pot and trying to create "ISSUES". Right now your taking a $ figure and trying to squeez everything out of the two shop owners. Save up some more $$$ then get your car done completely and correctly. Who cares what shop you go to at this point, just stop with this stupid thread.
#174
Originally Posted by strokedls1
As far as that 800rwhp dyno queen... lol. That thing had a 427ci and a blower and still ran like ****. I think mid to high tens is what I saw with a weak 60ft. We made harrys car run faster with a much lower rwhp number and full interior. A stock 6.0l gasket can handle a 250 shot. The reason you blew the gaskets is you are probably running one of the old style plates with uneven distribution. We did a lot of work on harry's nitrous system to make sure it worked the first time. May want to hook up the plate with the motor and elbow off to see how it is distributing.
very true. check which one of the shops has done similar setup and check for results. i know from experince no one here has done that setup locally. first thing to check for whos build motor handles that kinda of power. making the power with that turbo wont be a problem. how long will it handle, depands on workman ship and piston selction. good luck with your desion making. make sure those numbers are done on chasis dyno. pm me if you have any qustions on that setup.
#176
kiss my *** mo fo your the only one startin fights you stay out if you ask me. I will post when and where I want biyatch.
#178
i say pick the most expensive one, and double it, and just pay them that off the bat.
if you pay me the money i guarantee your car will have mad crazy powahs like mine. see my simple easy bolt on turbo kit makes 1176 power on stokc blocK!!! its cheap too i guarantee you'll be able to finally beat hondas and toyotas all day long.!@
