Western Members CA, AZ, NV, UT, CO, NM, HI
Abs/inop Light?
Old May 27, 2007 | 11:33 AM
StoreKeeper99Z28's Avatar
Question Abs/inop Light?
Changed from 17 to 18" rims amd now my ASB light says ABS OFF and ABS inop?
Any suggestions what that might be?
Thanks in advance
Bruce/StoreKeeper
Old May 27, 2007 | 11:37 AM
BigDaddyBry's Avatar
Knock something off in the process?
Old May 27, 2007 | 12:18 PM
01black's Avatar
mine went on after i got my car smogged a couple weeks ago but it went off after a few miles of driving....still dont know what set it off though
Old May 27, 2007 | 04:12 PM
6LITEREATER's Avatar
That's due to having the car on the rollers...
Old May 27, 2007 | 04:14 PM
Thanks in advance
Bruce/StoreKeeper
Did you end up changing the overall outside diameter of your tires and rims? Also, check your third brake light (on the spoiler)...
If the light bulb burns out it sets those lights off. Could be just a timing coincidence and you just need a new bulb or two...
Old May 27, 2007 | 08:30 PM
01black's Avatar
i thought so maybe...rear moving front not
Old May 27, 2007 | 10:54 PM
travie319's Avatar
check your wheel speed sensors......
Old May 29, 2007 | 10:08 AM
StoreKeeper's Avatar
Question
There are those?
Rx Bruce
Old May 29, 2007 | 11:22 AM
Ryne @ CMS's Avatar
LS1TECH Sponsor
right behind your hubs...
Old May 29, 2007 | 01:27 PM
Question
What should I check for ?
Thanks in advance
Bruce/StoreKeeper
Old May 29, 2007 | 03:12 PM
Thanks in advance
Bruce/StoreKeeper
Something dangling thats not connected.
Old May 29, 2007 | 03:20 PM
Wdpballer46's Avatar
my light came on not to long ago... what happened was there was a connecton loose on teh driverside infront of my axel. has nothing to do with changing the rims, but you might wanna check anyway.
