Zo6 Rims on Pewter Camaro
Hey guys, I just bought some silver ( non chrome) z06 rims off a 2002 vette. I am hoping there are some people that have done this and have some pictures I can see. I have tried to search and haven't found many.
They are 17x9.5 front 18x10.5 rear.
Thanks !
Thanks !
Customizing Director
You must have not searched enough or used the wrong terms because this has been covered a lot. Yes it will fit fine, but they will tuck in a bit. You can run a spacer to get them more even with the fender, but anything bigger then 1/4" and its recommended to replace the studs.
If you already have them, why not just put them on already?
I do not have them yet. I am waiting to get them. I was hoping to see some pictures of them on a pewter car.
Can you explain "Yes it will fit fine, but they will tuck in a bit. You can run a spacer to get them more even with the fender, but anything bigger then 1/4" and its recommended to replace the studs."
I dont quite understand. Thanks.
You should read this 1st. Everything you need to know. They should tuck in similar to mine since I was one of the 1st to purchase the replica's back in 2002 (maybe a mm or 2 more in). Click on my sig to see photos.
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
