Needs tires that hook 430 RWHP Over that winter I will be doing heads and be around the 430 RWHP mark. I will not be going to the track at all. I have heard Nitto's for cars that are bolt on and much after that they are no good. I have heard BFG KDW are good but to 430 RWHP? My question is what tire to go with. I need to be able to take turns and curves still. I will not be driving in the rain or if the ground is wet. Thanks. |
M/T ET street radials, Hoosier drag radials, or M&H drag radials... |
MT et street |
A buddy of mine was dead hooking his 500+ hp camaro with M/T ET street radials. Can go wrong with those, order them now 'cause I believe they're on backorder. |
Originally Posted by Red 01SS
(Post 10438406)
Do you have a 6-speed or auto? |
Originally Posted by PewterMNZ
(Post 10438429)
I should mention I still have a 10 bolt.. How will the ET streets work with the 10 bolt , automatic blow up? Here is a multi page thread of people still on 10 bolts. https://ls1tech.com/forums/drag-racing-tech/971047-how-many-you-10-bolts.html I run MT street radials pulling low 1.6 60's with the 10 bolt. |
Originally Posted by spyterus
(Post 10438444)
(Post 10438480)
M6 with 4.10's. I know people that have blown the 10 bolt with 3.42's on street tires at a stop light :jest: |
What he said.^^^^ |
remember planting power has just as much to od with suspension as it does a sticky tire. |
Originally Posted by kyles2000z
(Post 10438523)
MT Drag radials will handle corners better than the ET streets and almost hook as well. but for driving on street I woulnt waste my $ since you'll get about 5000 miles if u lucky. get another set wheels and tires for the strip. |
Originally Posted by Smokinlt1
(Post 10438764)
Damn age must be getting to me. I didn't see it. :emb: |
LOL I blew 2 ten bolts on Nittos. I had no complaints with my Nitto's, I was running a 315 on a 17x10.5 TTM and if launched at the right RPM with 4.10's they would hook and go, running around 18 PSI. If you are going to be putting A LOT of miles on the car within a year I would go with a Nitto. I went with M/T just because I only put about 1-2K miles on my car every year, so even if they only got 4,000 miles they would last me a few years. |
© 2024 MH Sub I, LLC dba Internet Brands
