LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   OEM deep dish c5's (https://ls1tech.com/forums/wheels-tires/1024683-oem-deep-dish-c5s.html)
Bishimus Nov 26, 2008 07:16 PM
OEM deep dish c5's
I just got in a set of thin spoke c5's 17x9.5 & 18x10.5.......the front fits fine but the back need spacers...can someone direct me to the spacers and the size I need PLEASEEEEE!! The offset for the front is 54mm and the back is 56mm. I have no idea where and what size spacers to get.:confused:
Bishimus Nov 26, 2008 09:18 PM
no one?...this sucks
maxgee Nov 26, 2008 11:32 PM
double check your rear is centered and what size tires are you running?
'Trust' Nov 26, 2008 11:57 PM
You will most likely need about a 3/4" spacer, it looks like its off by about .787" (20mm) in the rear. You need a 36mm offset on a 10.5-11" wheel.
Bishimus Nov 27, 2008 11:16 AM
295/35/18 on back 255/40/17 on front...sorry forgot to post that....so if I get a 3/4" spacer it will correct the problem?
maxgee Nov 27, 2008 03:17 PM
make sure it's centered with an adjustable panhard bar before you get the spacers.
Bishimus Nov 27, 2008 06:24 PM
rear is centered...i'm sorry I must be a newb at this - I have no idea what you mean by that or how to check..
maxgee Nov 27, 2008 10:48 PM
Do a search on the board, adjustable panhard bar center the rear of your axle, 99 percent of them are not centered perfect from the factory, so if it's off the left or right you will get rubbing.
© 2026 MH Sub I, LLC dba Internet Brands
