Sumitumo HTZR IIs vs. Nitto NT05.
Old 03-27-2009, 07:45 PM
LS1vazquez's Avatar
Default Sumitumo HTZR IIs vs. Nitto NT05.
The Nittos are nearly 200 dollars more for a set then the Sumitumo's, but are you getting 200 dollars more worth of tires?
Does anybody have any experience with these two tires?
Old 03-28-2009, 01:42 PM
Discount Tire's Avatar
You're trying to compare two different types of tires. The HRZII is an ultra high performance summer tire. The NT05 is a max performance summer tire. Max performance summer tires are great for racing (IE SCCA). The NT05 will have superior dry traction but won't last as long (10K-15K). The NT05 has a reinforced internal construction and reinforced outer shoulder blocks. This helps with stability at higher speeds. Not to mention the continuous center rib is huge! Check out this link...
