LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Wheels & Tires (https://ls1tech.com/forums/wheels-tires-17/)
-   -   DR's at high speed? (https://ls1tech.com/forums/wheels-tires/1095823-drs-high-speed.html)
XLR8N Apr 6, 2009 12:13 PM
DR's at high speed?
how stable are a set of 335/18's at high speeds on the highway? any pros cons?
Quick Sh0t xMLx Apr 6, 2009 01:53 PM
What brand? I used to ride around on my 275/60/15 DRs all the time on the highway. Cruising at 80, occasional races:emb: and I never had a problem. Mine were BFG, maybe some brands are different, I know the Hoosier DRs aren't recommended for highway driving.
XLR8N Apr 6, 2009 02:05 PM
im kinda tossed with either a mt dr in a 335/30 or the nitto 555r2's. but i will do a bit of highway driving and a few spirited jaunts in the 140+ range just want to make sure they are stable.
BobDoLe Apr 6, 2009 02:39 PM
the mt dr's aren't recommended (by manufacturer) for highway use, but that could be for a couple reasons. i've HEARD from a couple people that use them that they get pretty squirmy at speed, so they wouldn't recommend high speed highway driving at all.
the 555r2's would seem to be perfect for high speed freeway runs... but they have reinforced sidewalls which do not flex and they are NOT drag radials.
right now i'm on falken rt615's on front (not a drag radial or even an r compound tire, but pretty sticky with reinforced sidewalls) and kumho victoracer v700's out back (r compound road race tire with stiff sidewalls).
i'm pretty happy with the v700's, but you gotta heat them up to make them sticky and even then, they won't hook for me at WOT with my 3600 stall 2.5str torque converter. but they do grip pretty good rolling into the throttle and much better than the falken rt615s... so i'm thinking about going with 555r drag radials in the rear. only thing is that these tires i'm running now are very, very nice for high speed cornering and exiting corners with a good amount of throttle - and that's not something i want to give up.
but back to the DR at high speed - i think you want the Nitto 555R (not the r2).
i don't know how well they're going to handle above 140mph, but then again, its not like you have much sidewall there anyway.
00pooterSS Apr 6, 2009 08:16 PM
My BFG drags felt the same at high speeds as my sumitomo's.
linn.35 Apr 7, 2009 01:58 PM
My Nittos and BFGs were fine at speeds over 150mph. I could change lanes with confidence if needed. I now have 28 inch tall M&Hs and I would not even atempt to change lanes at that speed however, the car is fine at free way speed.
All tires are on a stock 17 inch wheel.
© 2026 MH Sub I, LLC dba Internet Brands
