Fitment Check-Please Look....
Old 04-14-2009, 04:54 PM
Striker's Avatar
Default Fitment Check-Please Look....
Im wondering if these would fit on my WS6 without any issue or looking funny, thanks a lot guys....
http://cgi.ebay.com/ebaymotors/19-Ve...1%7C240%3A1318
Old 04-14-2009, 07:28 PM
Gaunt's Avatar
If bolt pattern and offset match, go for it.
Check the sticky to see if it matches.
Old 04-15-2009, 07:01 AM
Striker's Avatar
its a 5x120(for BMW's) and the largest offset it comes in is 45mm........
Old 04-17-2009, 04:43 PM
Striker's Avatar
T t t!
Old 04-17-2009, 04:51 PM
ben77's Avatar
The 8.5 front probably would not be to your liking after you mount tires and put it on the car. Nice lip on em tho
Old 04-17-2009, 05:56 PM
Striker's Avatar
why do you say this?
Old 04-17-2009, 05:58 PM
ben77's Avatar
What size tire do you plan on runnin up front? If you're goin 275, they will not look good on a 8.5" wide wheel. You will need at least a 9" wide wheel for 275 tire, unless you like the bubbled look.
Old 04-17-2009, 06:00 PM
ben77's Avatar
Arent your stock wheels on the ws6 9" wide? why would you go smaller?
Old 04-17-2009, 09:22 PM
Striker's Avatar
No, if i were to get them staggered, i would not get a 275 on the fronts. However, I was planing on running the same size on all four corners. this was i can rotate and i like the bigger lip.
Old 04-17-2009, 09:36 PM
ben77's Avatar
Well its your car, but I will say that running same size tires on different size wheels will not look right. But thats just me =)
