Best Tires for 18" x 10.5" Wheels?
Old 06-07-2009, 02:04 PM
0235SS93's Avatar
Default Best Tires for 18" x 10.5" Wheels?
What do you guys reccomend? I'd like to run a dr, but I know they're uncommon in 18" sizes. I could go down to a 17" wheel in back to get a few more options, but I'd like to keep the wheels that are already on the car. This car is not driven often and only in good weather, so treadwear and wet traction isn't a big issue! And did I mention it puts down 550+ rwhp??? I know nothing is going to hold that much power great on the street, but I want as much traction as I can get. Also, what tire sizes will fit an 18" x 10.5" wheel?
Old 06-07-2009, 02:32 PM
Johnnystock's Avatar
http://www.discounttiredirect.com/di...95&ar=35&rd=18
The 2 first look good!!
Old 06-07-2009, 02:48 PM
0235SS93's Avatar
Are 295's wide enough for a 10.5" wheel? I don't want the sidewalls to lean in toward the center of the wheel.
Old 06-07-2009, 03:08 PM
Theyre the original Z06 wheels...you can go with 305, but bring the dough!
Old 06-07-2009, 03:09 PM
99Bluz28's Avatar
The minimum wheel width for a 295/35/18 is 10", so you're good to go!
Old 06-07-2009, 03:44 PM
0235SS93's Avatar
ok thanks! I'll see what tires I can get in those sizes. Any reccomendations?
Old 06-07-2009, 04:14 PM
99Bluz28's Avatar
Lightbulb
PM sent.
I've had good results dealing with the Tirerack, and Discounttiresdirect.
Old 06-07-2009, 11:21 PM
0235SS93's Avatar
I found a good deal on a set of M/T ET street radial II in 305/35R18...how would those fit the wheel and hook?
Old 06-08-2009, 02:24 AM
-98-Z28-Darkness-'s Avatar
yeah they will hook the best for that. but they wont last long.
i would got with 305 nittos since they last about 2-3 times longer then that but sacrifice a some hooking power.
Quick Reply: Best Tires for 18" x 10.5" Wheels?
