19 inch wheel and tire fitment...
Old 08-04-2009, 02:22 AM
BraveHeart's Avatar
Default 19 inch wheel and tire fitment...
Thinking about doing this..
02' WS6 Stock Height
19 X 9.5 +45 Front 275/35/19
Will these fit without any turn and rub issues?
19 X 10.5 +50 Back 285/35/19
Will these fit okay?
Tire calculator says it will fit up front, just would
like some real world help, thanks in advance
Old 08-04-2009, 08:08 AM
Xsta Z 28's Avatar
Wheels should be fine. Rear wheels, might necessitate a small amount of BFH to the inner wheel well, but I doubt it.
Tires are too tall of an aspect ratio. Should run a 30 series in those sizes to maintain OEM overall diameter of the tire.
Old 08-04-2009, 09:13 AM
kane's Avatar
My car is lowered over an inch in the back and I still fit 19 inch wheels with no problem.
Old 08-04-2009, 12:39 PM
99Bluz28's Avatar
Lightbulb
Up front 275/30/19s(25.5"), or 285/30/19s(25.73").
In the rear 295/30/19s(25.97"), 305/30/19s(26.2"), or 315/30/19s(26.44").
Old 08-04-2009, 03:24 PM
BraveHeart's Avatar
Not really caring to maintain the OEM diameter. A 30 sidewall seems a tad too small,
So anyone that has 35 sidewall all the way around on a 19" wheel. Please ring in with
your comments and tire sizes.. If I have to get 30, then so be it. thanks
Old 08-04-2009, 03:48 PM
kane's Avatar
I am running 285 35R19 in the rear on a lowered car with no problem!!! They should fit up front as well at stock height, if your car was lowered like mine then 19's up front might cut it too close.
Old 08-04-2009, 04:37 PM
sstg's Avatar
You'll want to do (30) so you don't have to recalibrate the speedo. I run 275/30/19's on all four corners with no problems.
Quick Reply: 19 inch wheel and tire fitment...
