Prostars cracking at every spoke This is quite scary, my rear 15x10 prostars. http://i226.photobucket.com/albums/d...g?t=1255485570 http://i226.photobucket.com/albums/d...g?t=1255485626 http://i226.photobucket.com/albums/d...g?t=1255485654 http://i226.photobucket.com/albums/d...g?t=1255485697 Every single spoke looks like that, on both sides. Anyone else ever have this issue? Kev D |
wow! haha just puttin some power to them! but no i have never seen that before! |
When did you install these? Did you buy then new or used? Maybe I can help? |
Originally Posted by wheelczar
(Post 12361880)
When did you install these? Did you buy then new or used? Maybe I can help? Kev D |
i would send these same pics to weld and see what they say. |
Originally Posted by quickbrick
(Post 12361918)
(Post 12361880)
When did you install these? Did you buy then new or used? Maybe I can help? :judge: |
A problem can occur on these wheels if the proper torque is overlooked when installing them. Or if they have been used on an application that they are not designed for. Also, using the correct washer and lugnut is crucial. They carry a 1200 lbs load rating per wheel. Do you know how they were used before you bought them? |
(Post 12362020)
A problem can occur on these wheels if the proper torque is overlooked when installing them. Or if they have been used on an application that they are not designed for. Also, using the correct washer and lugnut is crucial. They carry a 1200 lbs load rating per wheel. Do you know how they were used before you bought them? Kev D |
The older version of these wheels had a mfg date stamped around the bolt circle. Can you supply pictures of the front of the wheel? I would be interested in seeing these. I have seen this happen on Chevy trucks (5x5 Bolt Circle 1/2 ton) were they overload the wheels but it is usually on the front wheels only. Due to side load force from cornering and hard driving, but rears have hardly any side load at all. |
(Post 12362093)
The older version of these wheels had a mfg date stamped around the bolt circle. Can you supply pictures of the front of the wheel? I would be interested in seeing these. I have seen this happen on Chevy trucks (5x5 Bolt Circle 1/2 ton) were they overload the wheels but it is usually on the front wheels only. Due to side load force from cornering and hard driving, but rears have hardly any side load at all. Kev D |
Or how about running spacers like most people due? |
Originally Posted by tillery
(Post 12362157)
Or how about running spacers like most people due? Kev D |
Spacers do not usually create problems with the wheel itself. The problems with spacers is using correct lugs and maintaining torque specs. The lug holes would be compromised in most of these situations. Post your new pictures tomorrow and I will try to help more. |
What no drifting on Pizza cutters? LOL, J/K dude. Sux to see that happen-but its a good thing you caught it before it got real ugly. Its kinda rare to see one of these wheels break. |
(Post 12362297)
What no drifting on Pizza cutters? LOL, J . . . . Its kinda rare to see one of these wheels break. Sucks to see that happen, but I doubt drag racing wheels are designed to last forever . . . |
Originally Posted by Xsta Z 28
(Post 12362502)
FYI . . . It's the REAR wheels . . . . not the fronts . . . Sucks to see that happen, but I doubt drag racing wheels are designed to last forever . . . Kev D |
Damn thats not good man! I would definitely send some pics to Weld. |
The same thing happened to one of the fronts wheels on my old third gen a few years ago |
(Post 12362502)
Originally Posted by LS1RedZ
(Post 12362984)
Damn thats not good man! I would definitely send some pics to Weld. Thanks. |
© 2024 MH Sub I, LLC dba Internet Brands
