Old 04-26-2016, 02:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Tire Repair and Maintenance
Print Wikipost
Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
Old 03-25-2004, 01:06 PM
  #41
Todd@AZPowerAndSound's Avatar
+50 is correct. Some 315s are REALLY big and may rub, but highly doubtful if stock ride height. Youll be ok.
Todd@AZPowerAndSound is offline
Old 03-26-2004, 12:05 AM
  #42
Ferocity02's Avatar
Ok... Will Nitto 315's work on a 17x9.5" ZR-1 rim, since the Nitto's arent as wide as most tires? Thanks
Ferocity02 is offline
Old 03-31-2004, 03:58 PM
  #43
Xsta Z 28's Avatar
Exclamation
Technically NO.
Xsta Z 28 is offline
Old 04-14-2004, 09:44 PM
  #44
91camaroRS's Avatar
plz for give me im dumb but what do these number mean 7.0" +35 to +40 mm (215, 225, 235) the 3 diget 1's?
91camaroRS is offline
Old 04-20-2004, 03:04 PM
  #45
Xsta Z 28's Avatar
Exclamation
7" = Wheel Width
35 - 40 mm = Wheel Offset
215, 225, 235 = Tire Section Width
Old 05-24-2004, 03:07 PM
  #46
Raven's Avatar
How about this, guys: I am interested in a set of wheels that are 18" x 9.5" with a 35mm offest. Would wheels this size/offset work OK with my car?
From the chart in the first post I may be 3mm off what is acceptable My thinking is 3mm seems "close enough" but what do I know :shrug: Anyway, if anyone can help me out whether these wheels are OK or not, that would be great !
PS: Sorry if this is a dumb question.
TIA
Raven is offline
Old 06-01-2004, 03:43 PM
  #47
Xsta Z 28's Avatar
Exclamation
TIA
Man you are cutting the front ones close. The back would be fine, the front . . . not 100% sure. Look at my "FIKSE" album, for the 38 mm 9.5" wheel on the front of my SS. I know that one set oy my FIKSE are 37 mm and the other at 38 mm. Hope the pics help. Granted your on a Firebird and I think you have a bit more room to move outward than a Camaro.
Andy
- and never a dumb question - this wheel **** gets confusing.
Old 06-02-2004, 10:14 AM
  #48
Raven's Avatar
Thanks for the help, Andy Yeah, I think the front wheels will stick out too far with the 35mm offset I believe I'd be OK out back, but the fronts would likely look weird. Oh well, I guess my cc balance gets a break for now
Raven is offline
Old 06-08-2004, 04:16 PM
  #49
Xsta Z 28's Avatar
Talking
Thanks for the help, Andy I guess my cc balance gets a break for now
: LOL . . . The good olde CC balance! Good luck on your wheel search, and always glad to help.
Old 06-14-2004, 01:59 AM
  #50
1994ta's Avatar
I was selling a set of 2 3rd gen camaro wheels and drag radials in the for sale section, and someone just pointed out to me that they may not work with LS1 brakes being bigger than the LT1 brakes on my car? I'm pretty sure the wheels are 15 x 8. Positive on the 15" 70% positive on the 8". The tire size is 275/50/15. Does anyone know if these would or would not fit over the LS1 brakes? Either because of the rim not being tall enough or maybe not being wide enough? I need to make sure before I let them go.
1994ta is offline
Old 06-14-2004, 07:15 AM
  #51
Xsta Z 28's Avatar
Exclamation
As far as I know OEM 15" wheel do not fit on the 4th Gens. When the F-Car got the larger rear brakes, in 1997 or 1998 GM goofed and had to sell all cars with 16" aluminum wheels . . .
Old 07-02-2004, 02:17 PM
  #52
02Z28LS1's Avatar
ok, i got a question....how do you calculate the amount (if any) that the wheel will stick out past the fender for a given offset?
for instance, i buy 17"x10" +50mm rims with 275/40R-17's on them for all 4 corners....what math do you use to see if that will stick out past the fender, and if so, by how much?
and am i correct in assuming that the higher the offset #, the farther it will be sticking out toward the outside of the car? (i.e., a +55mm offset will stick out further than a +50mm offset)
02Z28LS1 is offline
Old 07-03-2004, 11:35 AM
  #53
02WS6Bird's Avatar
i think its the other way around the lower offset will stick out more....so 50 out more then 55
02WS6Bird is offline
Old 07-06-2004, 11:28 AM
  #54
Ws6t/a02txstyle's Avatar
Question zr-1
i was wondering if there was anyone out there who was running 17x11 zr-1's on all four corners and had any problems, i'm putting them on an 02 ws6 with factory ride heigth. also i've read that a 275/40/r17 will fit but wont look that pretty, if this is so, what would be a suggested tire size. any help would be appreciated.
Ws6t/a02txstyle is offline
Old 07-06-2004, 03:20 PM
  #55
Xsta Z 28's Avatar
Exclamation
It has been done, an avid road racer did it. A use of spacers, longer studs and minor grinding was required, use 315's on all four corners.
Old 07-06-2004, 03:22 PM
  #56
Xsta Z 28's Avatar
You have that backward sfor a newer F-car. the "smaller" the offset the further the wheel will move outwards.
As for you example, on the 17" x 10" wheel with a 50 mm offset, it will fit fine.
Old 07-24-2004, 10:50 PM
  #57
Bryan Wilkinson's Avatar
Todd,
Two Questions
Question 1
17X9 stock Rim 02 WS6 RIM. Regardless if the tire would fit under the rim or not, would a 305/?/17 or a 315/?/17 tire fit on these rims safely.
Question 2
18x9.5 Corvette Magnesium Rim. Regardless if the tire would fit under the rim or not, would a 305/?/18 or a 315/?/18 tire fit on these rims safely.
The reason that it does not matter is I am prepared to do the modifications to the wheel well to get the correct look, even it means tubbing the rear end.
If these tires will not fit these rims, can you tell me the maximum safe size for each.
Thanks Todd
Bryan Wilkinson
Bryan Wilkinson is offline
Old 07-25-2004, 12:12 AM
  #58
FenixSS's Avatar
A +54mm offset on a set of 18x10.5 or set of 18x9.5, would it require any BFH or fenderlip roll on a stock height SS? Tires would be 275 or 285 x35x18s all around.
FenixSS is offline
Old 07-26-2004, 09:25 AM
  #59
Xsta Z 28's Avatar
Originally Posted by Bryan Wilkinson
Todd,
Two Questions
Question 1
Niether tire fits a 9" wheel . . .
Question 2
The wheel should fit, I've seen them run on Camaros, not sure of the offset, so not sure if a spacer is needed . . Tires, technically neither fit a 9.5" wheel.
A 275 or 285 is your safe tire.
Thanks Todd
Bryan Wilkinson
  #60
Xsta Z 28's Avatar
The inner wheel well may need the BFH on the back, but no fender lip rolling.
Quick Reply: Wheels & Tires: Everything you should need to know is in here. A Must Read!!!!!!!
