need help with 15 inch rim/tire selection
im probably gonna end up going with summit stars since they are pretty cheap. mods in sig plus a 9 inch with 4.30s, 150 shot and stock 243s. gonna be spraying rite outa the hole throught the hole track. what size tire would i need so i dont run outa gear? also what summit stars would fit size wise? and would i need to grind my calipers?
I'd go with a 15x10 w/ a 7.5" BS and 5x4.75" bolt circle. If you are trailering the car to the track, go with a 28x10.5 ET drag. If you're driving there, a 28x10.5 ET Street bias ply. You'd probably have a rough time hooking up on a drag radial. And yeah, you're going to have to grind a little bit most likely.
