ET Streets vs ET Streets II
The 2's have more of a distinctive tread pattern - similar to m&h drag radials and kinda like a nitto drag radial. The compound is supposed to be the same, but after having both the 2's seemed harder when cold. The 2's are typically for larger wheels - probably because the tire and tread pattern is geared toward late model cars.
No compound difference, just the tread pattern. Also, you cannot get the ET Streets and ET Streets II's in the same sizes, i.e., you can't pick between a 275/40/17 I or II, they only come in I, same as you can't have a 315/35/17 in v.I, they only come in II.
I assume that they are phasing out the old tread pattern (I) and phasing in the new one (II). Probably a ton of the old pattern in stock, and since they never made a 315/35/17 in the first tread pattern it makes sense why it isn't available in both.
Long story short, they'll hook equally as good. I went 1.34 60' on my ET Street's (I) on the Bogarts, and the set on the Fikse's (II), seemed to hook just as well.
the stage 2 is port & polished
edit: trust, so your saying a drag radial hooked with your old beast at 800rwhp? care to elaborate? tire size?
to the OP, go with whatever he used and im sure it will work for u. any results on viper with nawz?
http://www.youtube.com/watch?v=YMT0SDG_oIM
No numbers out of the Viper on the n2o yet.
On the street wheels, 315/35/17's, I didn't drive the car much, but after about 2k they didn't show much wear, I've heard of 8-10k out of them if you're not on it all the time.
1 Post
Yes an auto does shock the tires but the 6 speed really lays the smack to the tire, thats why its soo important to have da shocks and a bias ply in the rear to keep the rear tire from unloading after the shock..Bouncing kinda like a ball in a sence!
