zr-1's won't fit one trans am wheel?
Old 03-26-2010, 06:35 AM
Shroomun's Avatar
Default zr-1's won't fit one trans am wheel?
i have a set of zr-1 rims. they are 10.5 all the way around. anyway on the rear passenger side there is a pieces that sticks out off the spring mount and it is stoping the tire from going all the way on. wth?
Old 03-26-2010, 07:00 AM
bigj2717's Avatar
Are you trying to put the rim on with the rear hanging? It might be getting caught on the bumpstop put and jack under the rearend and lift it that way that should help
Old 03-26-2010, 10:26 PM
WOOS1's Avatar
Definately must jack up or support the axle to get them on. Will leave nasty gouges if you try to take them off on a lift. You can also premanently eliminate the problem by grinding off the bumpstop mount.
Old 03-27-2010, 08:44 AM
Shroomun's Avatar
you guys are awesome fit perfect now. I wonder why my camaro didn't have this problem?
Old 03-27-2010, 12:18 PM
KL20's Avatar
i had to eliminate that problem also, that mount is a bitch to grind off. i had to file down the aftermath too just so there wasn't a sharp edge for that "just in case" scenario.
Old 03-27-2010, 12:24 PM
LS1CALIBOY's Avatar
Where did you get 10.5's all I've seen is 9.5 and 11's? thats pretty wide for the front are you doin some road racing?
Old 03-28-2010, 08:39 AM
Shroomun's Avatar
nah it's just they were cheap (400 bucks) with new tire and he said that's what they were all the way around. Is there anyway to measure this with the tire on?
Old 03-28-2010, 08:57 AM
the_merv's Avatar
What size are the front Tires?
Old 03-28-2010, 09:49 AM
Spahny72's Avatar
Throw some pictures up...im sure im not the only one thats curious how she looks
Old 03-28-2010, 08:47 PM
Shroomun's Avatar
275/40 and i will tomorrow it's raining right now
Old 03-28-2010, 09:31 PM
bigj2717's Avatar
If the fronts are 275's then it'll be a 9.5" rim.
Old 03-29-2010, 06:17 AM
Shroomun's Avatar
So a 275 couldn't fit on a 10 or 10.5? Sorry just don't know tires or rims real good. Just going on what he told me...I put 275's on all the rims also.
Old 03-29-2010, 06:33 AM
bigj2717's Avatar
A 275 on a 10.5" rim will looked streched
Old 03-29-2010, 07:03 AM
Shroomun's Avatar
oh ok no they don't look stretched to me.. I'm going to put those pictures up today to make sure though. Thanks for all the help cus i was going to trade 2 of them for 9/9.5's so hopefully I won't have to go thru that trouble now.
Old 03-29-2010, 07:33 AM
bigj2717's Avatar
You could also take them to any tire shop and they should have some calipers that fit over the tire and measure the rim
Old 03-29-2010, 10:06 AM
Xsta Z 28's Avatar
The seller probably measured the OVERALL width of the wheel from outside face to outside face. Wheels are measured by the insides of the wheel flanges . . .
So if you're told they are 10.5" wide, then they are actually 9.5" wide . . . A typical wheel flange is 1/2" thick.
Old 03-29-2010, 12:08 PM
meine96ws6's Avatar
i used to run 275 all the way around... i miss my zr-1's..
Old 03-31-2010, 05:23 AM
Shroomun's Avatar
yeah I think the only other wheel I would want to run is the c-6 as far as regular old wheels...course I'd love some welds to
Old 03-31-2010, 06:21 AM
Donohue96M6Z28's Avatar
I agree that they are likely 17x9.5 all the way around. But to confirm, you can take the wheel off the car and look on the underside of the spoke. But if they are 17x9.5 all the way around, I'm surprised that you had to lift the rear axle to get the rears mounted, thats usually a 17x11 wheel issue.
